Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > Error with DRL kit
      11-11-2010, 10:12 PM   #1
jahmed78
jahmed78's Avatar
45
Drives: 2007 BMW e90 335i
Error with DRL kit
I installed WeissLicht LED halo bulbs (angel eyes) and a Daeos DRL harness and I keep getting error codes every now and again for my front right lamp. I know if you take the lights off the auto setting, error codes are expected. However, I haven't been messing with that at all. Anything I can do?
2007 335i e90 - black on black w/wood trim and iDrive
19" BMW M-Performance wheels, ST coilovers, m3 rep front bumper and skirts, CF Hamann rep diffuser, Remus Race quad exhaust, aFe DCI, LED angel eyes & DRL kit,
      11-11-2010, 10:31 PM   #2
jahmed78
jahmed78's Avatar
45
bump
      11-12-2010, 05:46 PM   #3
jahmed78
jahmed78's Avatar
45
nobody else had this problem?
      11-16-2010, 06:08 PM   #4
SV Concepts II
SV Concepts II's Avatar
269
Drives: E90 M3
Location: 1460 White Oaks Rd. Suite F Campbell, CA 95008
Do you have the DRLs enabled on the iDrive system?
      11-16-2010, 06:23 PM   #5
jahmed78
jahmed78's Avatar
45
nope i disabled the DRLs in the iDrive system because the ugly halogen high beams were turning on with the halos.
      11-16-2010, 06:25 PM   #6
SV Concepts II
269
Drives: E90 M3
Try swapping the WL LED unit between sides, to see if the error pops up on the other side. If it does, we can replace it under warranty.
      11-16-2010, 07:07 PM   #7
jahmed78
jahmed78's Avatar
45
Hmm I'll try that when I take my wheels off next. So much work to get to the bulbs!
      11-16-2010, 07:18 PM   #8
WingZeroX5
WingZeroX5's Avatar
766
Drives: F80 / F30
Initially I didn't have the problem, but about a month into it, with dial set to Automatic, the car shows an error saying my low beam bulb is out...
I flipped it back to low beam and back to Automatic, it goes away. Happens here and there but mostly during dusk/dawn
If it helps, I turned off DRL.
      11-16-2010, 07:26 PM   #9
Noxious_
27
Drives: 08 E90
That sucks, its a pain to reinstall those lights. I have the harness and lux and have never had a problem with errors or uneven light.
      01-17-2011, 10:10 PM   #10
rubdom
Drives: 08 E90 AW
I have the same error. I have an 08 E90. its the harness not the LED upgrade.
      01-17-2011, 10:19 PM   #11
bbbuzzy
18
Drives: '13 335is convertible (manual)
I thought the error message was only an issue for early build '06's. Anyone from jlevisw.com care to chime in and straighten things out?
'11 X3 xdrive35i
'15 Sienna Limited AWD (road tripper)
'06 330i MT, sport,premium (retired)
      01-19-2011, 09:50 PM   #12
bbbuzzy
18
Bueller?
'11 X3 xdrive35i
      01-19-2011, 11:38 PM   #13
rubdom
Drives: 08 E90 AW
The error according to the site should only happen on some "older" cars when (and only when) you switch to "parking". I had it when my headlights lights came on in auto. I contacted jlevi and they were no help, just blew me off really. I think I might have fixed it by replacing the crap wire taps that came with the harness with quality taps. I haven't had the problem since, but it's only been 2 days.
Try it and see if it works. Don't waste your time with jlevi they won't help you, sucks too I was going to order about $2000 in additional mods from them. I'll go elsewhere now that I know their support sucks.
Good luck I'll let you know if I get any errors.
      02-22-2011, 01:32 PM   #14
virk007
virk007's Avatar
34
Drives: 2007 E90 328i AW
2007 BMW 328i  [0.00]
2000 BMW 323CI  [0.00]
I have a canadian car, currently in the states, my DRL low beam stay on always can I install the Daeos harness or will it cause errors?
      02-22-2011, 01:48 PM   #15
rubdom
Drives: 08 E90 AW
You may be able to code it out. IE turn off DRL's and turn on AE's without the harness. I did this with my 08 E90 just a couple days ago. See this thread:
http://www.e90post.com/forums/showthread.php?t=451145
See page 72 post 1549
Some older E90's don't have the option but just depends on your build date. If not you never know if the DAEOS harness will give you errors until you install it and good luck getting support from jlevi.
Goodluck!
Tags
angel eyes, drl, halo
