Thrifty Brake Job
11-10-2010, 04:59 PM | #1 |
13
Rep 89
Thrifty Brake Job
My car tells my it needs service, BMW stealership says it needs front pads and sensor. Parts and labor will run me almost $500. I ordered the pads and sensor online for under $100 (http://www.rmeuropean.com/Part-Numbe..._657B4470.aspx) and have a great mechanic who specializes in high end cars who will do the install for $80.
I am saving hundreds here... is there anything wrong with this? And yes, I will bed the brakes in after the install... |
11-10-2010, 05:04 PM | #3 |
103
Rep 2,783
For the hell of it, I would change the rear brakes too especially if the Indy will only charge you another $80 in labor.
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
11-10-2010, 05:05 PM | #4 |
Dillo boxers
272
Rep 3,360
If your guy is an experienced BMW or european car mechanic, then no. There is no material difference in the quality of the work done by dealerships and indy shops, except for the price of the work.
2019 M5C Matte MBB / Tartufo
11-10-2010, 05:07 PM | #6 |
103
Rep 2,783
^ Really? If so, then no.
11-10-2010, 05:11 PM | #7 |
103
Rep 2,783
Winter is coming, when was the antifreeze last changed? Since you found yourself a good Indy ask him about that too. Also, ask him what other maintenance items he would recommend should be performed.
11-10-2010, 05:19 PM | #9 |
39
Rep 1,558
Your car will tell you when the coolant needs changing. Just like the brakes.
Sport pack, JB3, Dci, factory oil cooler, 18" M3 reps, Michelin PSS, painted trim, black grills, smoked side markers, LED plate lights, H&R coils, Borla catback |
11-10-2010, 05:20 PM | #10 |
119
Rep 2,312
Honestly I looked at the complexity of changing the brakes...you could do it yourself -- its not that hard
I don't see an independent having trouble with it. The only thing I don't get is -- do our sensors have to be replaced...or just reconnected to the caliper? |
11-10-2010, 05:24 PM | #11 |
13
Rep 89
Sensors have to be replaced - (there is only one on the left wheel). I ordered it with the pads for $15.
Hypothetically, I could do this myself. However, I may be good at taking things apart - not so much putting them back together. I have a strong feeling the the car will end up on a jack with no wheel, and I will have no idea how to get it back together. |
11-10-2010, 05:33 PM | #13 |
13
Rep 89
I was less concerned about the Indy mechanic and more concerned with the quality of 'non-bmw' OEM parts. With the amount I'm saving, it almost felt too good to be true.
A knowledgable friend informed me that I will need one more part. Brake pad clip...something along those lines - which I can get at the dealer for pennies.. |
11-11-2010, 08:49 AM | #14 |
103
Rep 2,783
No it won't, I think you are mixing up one of the symbols. I believe it must be changed every 5 years. I prefer to change every 2 years. Coolant is cheap. Water pump is expensive. (Coolant not only protects against freezing it also lubricates the water pump.)
11-11-2010, 08:54 AM | #15 | |
103
Rep 2,783
