SuperFlow flow bench testing N55 air box and filters
11-10-2010, 02:03 AM | #1 |
Supreme Allied Commander
3843
Rep 54,376
Drives: F80 M3
Curious to know what a few different type of filters would flow vs no filter at all? Here are the results measured in percent of flow...
Flow bench set-up to suck through at 22 inches of vacuum, ambient temp was a cool 70F.. BMW Intake Box with stock, clean air filter....90%...Remember, this is a clean paper filter, put a few miles on it, the percent flow will drop drastically BMW Intake Box with new/clean AFE Pro-Dry filter...90%...To our surprice there is no flow gain with the AFE filter at all BMW Intake Box with HPA used/~1500 miles high-flow foam filter...90.5%...The result isn't as impressive as we thought it would be, but it does flow better the previous two filters tested, even with 1500 miles already on it. We are not surprised this additional air flow translated to 4-5 hp and 4-5 ft/lb at the wheels on a dyno recently done by "FrankiE90" http://www.e90post.com/forums/showthread.php?t=416803 You ready to see the flow percent with no filter at all? BMW Intake Box with no air filter at all.... 92%...It's far from 100%, there is restriction with the oem box for sure and leaves room for improvement. Why foam? Because, compared to paper or other filter technologies, "Open Cell" Polyurethane foam achieves optimum performance against three key criteria: Maximum Air Flow - the ability to allow air to pass through without causing a large drop in pressure. Cleaning Efficiency - the capability to arrest a high proportion of airborne dust while feeding the engine clean air. Dust Load-up Tolerance - the capability to absorb a large amount of dust without reducing air flow capacity. Last edited by HP Autosport; 11-11-2010 at 05:22 PM.. |
11-10-2010, 02:24 AM | #2 |
Selling drugs to BMW addicts
17
Rep 468
So, no need to purchase an aftermarket filter. Those .5% are in my eyes as effective as not having lunch before getting in the car.
Just my .02...
Quality US Spec Used Cars for Military Members stationed in Europe. Specialized in BMWs and MINIs up to 10k miles. |
11-10-2010, 02:39 AM | #3 | |
3843
Rep 54,376
Drives: F80 M3
By the 3rd time you replace your paper element, you could have bought a higher flow foam or another media, just clean it(oil if needed) and reinstall when it's dirty. |
11-10-2010, 02:57 AM | #4 |
161
Rep 7,377
Can you get a version of the foam filters that fits the injen intake?
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
11-10-2010, 10:11 AM | #8 |
3843
Rep 54,376
Drives: F80 M3
Have a look at the Dyno results.
11-10-2010, 10:49 AM | #11 | |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
I've been preaching this ever since I joined this forum... Only now it is beginning to trickle down...? On the side note: you should do a test on all of the oiled filters and you will be absolutely astonished how badly most of these filters do!
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
11-10-2010, 10:53 AM | #12 | |
147
Rep 2,014
11-10-2010, 10:55 AM | #13 |
1121
Rep 5,396
11-10-2010, 10:57 AM | #14 |
70
Rep 1,565
According to the dyno, it appears 3.4whp and 3tq.
2020 M340i: Dravit Grey Mettalic. Loaded.
11-10-2010, 11:04 AM | #15 |
95
Rep 1,659
11-10-2010, 11:17 AM | #16 |
I even mod my cereal
246
Rep 3,441
Drives: 11 ZCP DCT M3 14 328d 21 GT4
I bought an ITG panel filter from HPS for the N54 airbox and it definitely feels better than the stock filter. I have dealt with many different intakes on my previous cars and am not falling victim to the "placebo affect". The stock panel filter is so restrictive that almost any after market filter is going to flow better.
The reason I went with a panel filter (for now) is due to not liking the designs of the dual cone filters currently on the market. Almost all of them are suseptible to heak soak, not matter what that ONE posted test shows. Sit in stop and go traffic and your DCI intake is sucking nothing but hot air due to zero shielding.
2011 Mineral White M3 ZCP - Opticoat, Ventureshield, some CF, B&B exhaust, AFE Intake Vorsteiner VFF 101s Ohlins
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser |
11-10-2010, 11:23 AM | #17 |
Rep 265
Those graphs are quite interesting. It doesn't seem to be a consistent 5hp gain at all only between 5.5k and 6k RPM. Its also a very small gain compared to the noise on the chart, some other variable such as engine temp or something else might have also caused the gain. If you look at 5.5k to 6k band, it runs exactly in time order, that is each successive run has more HP than the one before it.
Regardless 5HP isn't really enough to matter. The better/worse filtration of the foam filter could have significantly more long term effects. |
11-10-2010, 12:06 PM | #18 |
246
Rep 3,441
guys, don't sleep on the torque gains....
11-10-2010, 12:10 PM | #19 |
273
Rep 5,876
This is an excellent post that shows there's as much gains with an aftermarket filter inside the stock airbox as some of us originally thought..~5whp...also shows that the stock intake design is good at "stock-like" power levels...
11-10-2010, 12:28 PM | #20 |
819
Rep 3,341
Drives: 2022 M3, 2022 X5 40i;
My question is though, why haven't automakers adopted these as standards, and continuously go back to paper filters?
Is it just a cost thing? What's the difference between that and a K&N filter? |
11-10-2010, 02:12 PM | #21 | |
246
Rep 3,441
11-10-2010, 03:02 PM | #22 |
1121
Rep 5,396
Umm, they put the exact same filters everywhere else in the world, yet the emissions standards are completely different from place to place. So that's highly unlikely.
Quality paper filters actually perform well and work CONSISTENTLY in all kinds of conditions. Ever wondered what happens to an oil filter when driven in extreme heat or extreme cold? The efficiency of the such filters changes in different conditions. Also, paper filters are perfectly sufficient for OEM applications and stock power levels.
