brake squeal
11-09-2010, 04:15 PM | #1 |
Rep 9
brake squeal
my brakes have only about 8K miles on them, brand new brakes all around when I purchased it certified. The dealer said I should get about 20-40K miles on new brakes before they should need changing, dependent of course on how I drive it, but I am getting this slight squeal just before a full stop. I try to be gentle on the brakes, but I find that the more gentle I am trying to be, the more they will squeal. Doesn't happen when I brake harder, nor does it happen all the time. It is embarrassing, because I know the brakes are still in good shape. Is there something I can do to help this, or do I just have to ride the brakes harder?
11-10-2010, 09:53 AM | #2 |
146
Rep 1,403
This was a huge issue for me in my 2008 and I was repeatedly told (even by friend's at the dealership) that this was caused by the brake sensor rubbing on the bmw brakepads and that there was nothing that could be done about it.
I think the only way to remedy it is to switch to different brake pads.
11-10-2010, 09:59 AM | #3 |
253
Rep 7,089
Drives: '06 AW 330xi
No, the way to remedy it is to buy a new sensor (granted the one you have is worn) and tie it off to the side. However now YOU have to keep track of the wear.
I had this squeal as well and I just changed my rear rotors and pads...no more squeal. When that sensor starts to wear I bet the squeal will come back. |
11-10-2010, 10:21 AM | #4 |
146
Rep 1,403
My brake squeal was so loud that friends driving next to me always thought something was wrong with my car. It was SO obnoxious. Luckily I have a new 2011 now. Knock on wood.
11-14-2010, 02:20 AM | #5 |
27
Rep 1,129
I have the same problem--it's do freaking annoying and gives me a headache!!! BMW should fix this issue...it's very embarrassing...
2013 911 4S ...GT Silver/Espresso custom build w/ lots of options and all alphabets soup!
2007 335i Coupe ...TiAg/Grey custom build...Sold! |
11-14-2010, 09:31 AM | #7 |
Laker Land
16
Rep 802
me 5. they replace my rear rotors and pads. it was good for maybe a couple hundred miles. now its coming back again..
any aftermarket options? |
11-14-2010, 11:57 AM | #8 |
253
Rep 7,089
New pads/rotors don't matter...unless they really are squeaking.
But the more common squeaking culprit is the sensor. Replacing the pads and rotors also requires the replacement of the sensor. The sensor does not start wearing right way...it takes some time for the pad material to become even with the sensor and thus the reason why after a brake change, the squeal is gone. Like I said before, you can tie the sensor off to the side. |
11-15-2010, 12:51 PM | #9 |
29
Rep 533
I had the same problem but the dealer fixed it for free since I am still under warranty.
COH4777
2007 335i Coupe - Jet Black / Coral Red / Aluminum Trim / 6MT / Sport / Premium / CA / Navi / iPod + USB |
11-18-2010, 12:21 PM | #11 |
48
Rep 334
SI B 34 08 08 "Brake Squeal from Pad Wear Sensor"
http://www.bmwtis.com/tsb/bulletins/...p/B340808g.htm
R56 Cooper S
E92 335i E30 332is Burger Tuning, Evolution Racewerks and VRFS in Puerto Rico... |
11-18-2010, 12:53 PM | #12 |
146
Rep 1,403
Mine would squeal even when I wasn't on the brakes. I'd be crusing at 5-10 mph and it would squeal obnoxiously loud the entire time. I went on a cruise and people were asking me if something was wrong with my car. Of course bmw just said multiple times that it's "normal".
11-23-2010, 07:48 PM | #14 | |
Rep 27
only squeals at low speed acceleration not even on braking. Gone to the dealership twice & they refuse to replace them they say its BMW's "special brakes"...very special |
