WTF....Can't figure this bumper out?
11-09-2010, 03:28 PM | #1 |
58
Rep 512
curious what the part is called, that way I can search for it?
Or, how do you remove these parts? They are the mesh that goes from fog light to fog light, under the kidney grills. Below the license plate area...... Can't seem to take them off? HELP....want to make the TiAg lines, Black! |
11-09-2010, 03:36 PM | #2 |
122
Rep 6,594
I can tell you what they are, but don't know how to remove them off the top of my head. People paint them often though, so there must be some trick to getting them out.
#7 - Finisher Rod (left/right) #8 - Finisher Rod (center)
X7 LCI // Incoming C7 ZR1 ZTK // Sebring + TRX // Hydro + Raptor Gen1 Roush // Tuxedo |
11-09-2010, 03:40 PM | #3 |
69
Rep 1,239
you can refer to the DIY here for pictures of the tabs: http://www.e90post.com/forums/showth...ghlight=grills
The tabs are notched. Simply pull down on the tabs (read: away from the grill) while applying pressure to the grill. They will pop off. |
11-09-2010, 04:20 PM | #5 |
58
Rep 512
Thanks a million, however do I have to remove the entire bumper to get those finisher sections off from the backside?
11-09-2010, 04:22 PM | #6 |
58
Rep 512
Since I've got the experts......shoud I go with 15 or 20 mm spacers in the rear????
11-09-2010, 04:29 PM | #7 |
122
Rep 6,594
Either should be fine on the pre-LCI E90. Keeping the stock 162s for now? Even dropped, 15mm should be fine without any rubbing. If you go 20mm you might need to roll the fenders since you're dropped.
11-09-2010, 04:47 PM | #8 |
HYEPWR
100
Rep 2,868
I had 18mm spacers on my e92 with a drop, no rubbing. Keep that in mind as they might work for you as well.
-D
2002 330ci Titanium Silver / Gray
2005 X5 3.0i Black Sapphire Metallic / Black 2002 M3 Laguna Seca Blue / Black 2001 M5 Jet Black / Black |
