New HPA E9x 3 Series Rear Ride Height Adjusters
11-02-2010, 06:14 PM | #1 |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
A pair of adjustable height rear spring platforms, designed to work with 60mm inner diameter coilover rear springs mounted in the stock spring location at the rear of a BMW E8x (1 series) or E9x (3 and M series). These are high quality products made by HPA right here in the USA, with easy adjustments. The thread used is self locking once any load is applied.
The material for the rest of the assembly is made up of black and HPA blue anodized aircraft grade aluminum alloy. These can be adjusted from a minimum of 0.5" thick to a maximum of 2.75" thick. These can be adjusted independently of each other and is great for corner balancing of your BMW. This particular model has been optimized to run at the top of the spring on the back of a BMW E8x/E9x. The locating stub fits in the factory location and replaces the bulky factory locating stub/hat, which inhibits ride height adjustment with other similar rear ride height adjusters. |
11-05-2010, 04:01 AM | #3 | |
263
Rep 2,559
I'm looking for exactly something like that for my Bilstein B16 coilover (for the rear). The stock "bad roads package" which has plastic spacers similar to these here doesn't fit any more due to the coilover. Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
11-05-2010, 10:22 AM | #4 |
3847
Rep 54,376
Drives: F80 M3
The adjusters weren't designed for that purpose but I'll check fitment for you guys on Monday.
11-05-2010, 12:02 PM | #5 |
Major nutz
86
Rep 1,488
Drives: '09 n54 e92xi, 6mt, kw v3
Harold, you must have read the thread where I complained about KW's rear spring perch platforms weren't long enough for my taste. I have about 4 or 5 threads showing on the ~inside~ of the perches, this after a corner balance, and I'm still ~low~ in the back. How much longer are these than the KWs, if you know?
11-05-2010, 12:11 PM | #6 |
Major nutz
86
Rep 1,488
Wait a minute, what coilovers have this spec? Edit: BTW, the picture in my "garage" of my rear suspension were taken immediately after I did the install, and before I raised them and corner balanced. With the collars at the position in that picture (one thread of the platform coming through the collar), my rear end was absolutely slammed.
11-05-2010, 07:11 PM | #7 | |
3847
Rep 54,376
Drives: F80 M3
If you are looking for higher ride height from your KW, these are it. |
11-05-2010, 07:40 PM | #8 |
Major nutz
86
Rep 1,488
Sold. I'll be contacting you shortly. I don't need go any higher, but I do want to ride on more thread contact! Would you recommend thrust sheets? Or do I need to wait for the Swift spring purchase?
11-05-2010, 07:52 PM | #9 |
Major nutz
86
Rep 1,488
Very happy you made a great product, not very happy at all (more like ) that KW didn't make 'em like this in the first place. You AST guys reading this?
11-05-2010, 08:44 PM | #10 | |
3847
Rep 54,376
Drives: F80 M3
If you are going to spend the labor replacing the height adjuster, it may be a good time to replace the rear springs of a differnt rate(if you are considering that now) as well to save on labor. |
11-08-2010, 11:34 AM | #11 | |
263
Rep 2,559
Alpina_B3_Lux
11-09-2010, 01:56 PM | #12 |
3847
Rep 54,376
Drives: F80 M3
03-07-2011, 07:05 PM | #14 | |
1821
Rep 5,337
You can't adjust ride height when the springs are loaded. Hundreds of pounds of force on the adjusting collar means there's no way to turn them, regardless of the design.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
03-15-2011, 11:28 PM | #15 | |
3847
Rep 54,376
Drives: F80 M3
The thrust sheets do help a bit. Sometimes some dry lube on the threads of the height adjusters can do wonders and don't attract dust or dirt down the road. Below is the setup we run on our 135i with helper springs and radial thrust bearings. Adjustment is easily made with this setup and the springs can be changed out in a matter of seconds. For those like to tinker with their vehicle's ride height frequently, I recommend getting the radial thrust bearing to make the adjustments much easier. Last edited by HP Autosport; 03-16-2011 at 01:28 PM.. |
03-16-2011, 01:06 PM | #16 | |
146
Rep 1,922
Drives: E90 335i, E70 X5
it could be done but just be ready to spend some elbow grease, once you get the momentum when turning it, it's not too bad. but like blisstik mentioned, a spanner wrench with notch would be a better choice =)
-eric
E90 335i TiAg *STOCK* see my garage for mod list.. E70 X5 SGM *try to stay stock* :/ |
03-23-2011, 12:57 AM | #17 | |
3847
Rep 54,376
Drives: F80 M3
04-01-2011, 12:26 AM | #18 | |
NC BMW
43
Rep 461
Drives: 2013 335is , 6 speed mt
Raise Rear Ride Height
Hello, I have Dinan springs and want to slightly raise my rear height. With these Rear Ride Height Adjusters, would I be able to raise one side by about 0.5 inch and the other side a bit more ?
Thanks, - Ray - Quote:
Cobb AP v3 - Wedge tuned, Cobb FMIC, AR catted DP's, Dinan Stage 2 suspension, Koni Yellows, M3 control arms and strut brace, BMS chargepipe, BMS OCC, BMS Sport Oil Cooler Valve, BMS CDV, RB Turbo PCV, aFe Stage 2 SI intake w/scoops
04-01-2011, 02:15 AM | #19 | |
3847
Rep 54,376
Drives: F80 M3
Yes, you can. Just by adding the height adjuster alone will probably get you the 0.5" you need and since they are adjustable, you can get go much higher. If you are thinking about upgrading your rear springs, this would be a good time as well. Harold |
08-25-2011, 03:16 AM | #20 |
240
Rep 587
Is it KW coilovers that have 61mm inner diameter?
Is it the same with KW coil springs? And how do you adjust it? I don't see any tap for the tool to grab? How much are they?
435d xDrive & M5 F90 Frozen dark silver metallic |
08-30-2011, 12:59 AM | #21 | |
3847
Rep 54,376
Drives: F80 M3
These were designed around the Swift 60mm ID springs. No tool needed as these are recommended to be installed with Swift thrust sheets and you will be able to turn the adjuster by hand in most cases. Here is a link to our web store with price: http://www.hpashop.com/product.sc?pr...categoryId=238 |
