2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding Has anyone been able to play music directly from the iPhone 4?
      11-02-2010, 06:41 AM   #1
krell
14
Drives: F11 520D
I have a F11 that was built in October this year (not sure which week, but it was week 40 at the earliest).
When I plug the iPhone 4 into the USB socket using the usual white cable it comes with, some of the phone functions freezes up, and the car doesn't recognize the phone.
I was told by the dealer that I needed a Y cable at a cost fo £40. When using this cable the car reports that the phone is not compatible.
I know the iPhone 4 cradle isn't available yet, but there must surely be a way to play music stored on the phone?
      11-02-2010, 07:01 AM   #2
sundance
Total Newbie
sundance's Avatar
Drives: 2011 520d SE
Do you have option 6FL 'USB audio interface' in your vehicle? It's not standard on UK 520d SE for example.
Perhaps others can advise...
      11-02-2010, 07:57 AM   #3
krell
14
Drives: F11 520D
Yes, I do have the USB audio interface. That's what I plugged the iPhone into.
      11-02-2010, 10:36 AM   #4
Harvest
Sweden
Drives: F10 530d M-sport
My Iphone4 works fine with the white standard cable and i can play all the music stored on phone. . My car is build week 39.
I believe that just cars build before september needs Y-cable.
      11-02-2010, 11:08 AM   #5
kscarrol
kscarrol's Avatar
8908
Drives: 2021 X3 M40i, 1974 2002 Tii
Harvest is correct. Return the Y cable and use the white cable that came with your iPhone. The cable is likely the cause of your problem.
2021 X3 M40i
1974 2002tii, Inka, 5 sp manual
BMWCCA # 327475
      11-02-2010, 11:13 AM   #6
krell
14
Drives: F11 520D
Thanks Harvest and kscarrol.
My wife tried the white cable with her phone and it didn't work. I'll try it with my own phone.
What do you do once the phone is plugged in? Do you need to go to a particular iDrive menu?
Also, does the white cable charge the phone?
      11-02-2010, 12:08 PM   #7
F10550xi
26
Drives: 550xi ZMP
I recently had a 750Li demo and we were able to play music from my iphone 4 via bluetooth. With the new combox upgrades, the f10 should have the same ability.
      11-02-2010, 12:11 PM   #8
schneeky
F11 535d SE week 40 production
12
Drives: BMW F11 535d SE Touring
Iphone integration
Works perfectly with my iPhone 4 - seamless integration; album art, playlists etc. all work.
You need to select CD/DVD then external devices you should see your iPhone with the USB symbol. Select that and you will see the usual iPhone category criteria.
Some very poor photos attached
      11-02-2010, 12:21 PM   #9
krell
14
Drives: F11 520D
Many thanks! I'll try it tonight.
      11-02-2010, 12:50 PM   #10
kscarrol
kscarrol's Avatar
8908
It will be under CD/Multimedia then under external devices. Your iPhone will show up with the name you gave it...
2021 X3 M40i
BMWCCA # 327475
      11-02-2010, 02:12 PM   #11
nosnoop
838
Drives: 5 Series
And you can also play music through Bluetooth Streaming.
Your iPhone 4 does not need to be plugged in at all!
Forget about the USB/cables....
      11-02-2010, 02:40 PM   #12
tdjwt
Drives: F10 535D M Sport
How do you do it through Bluetooth streaming?
      11-02-2010, 02:48 PM   #13
Harvest
Sweden
Then i stream music through bluetooth i cant se any playlist, songtitels its only possible to toggle forward or backward is this right or is it something wrong with my bluetoothconnection?.
      11-02-2010, 02:56 PM   #14
F11Black
Member
11
Drives: F11 520d Black Sapphire
Yes, I get the same with my iPhone 3GS. I think the car is behaving like a Bluetooth headset and the phone doesn't send album art or track titles over Bluetooth
      11-02-2010, 03:45 PM   #15
Harvest
Sweden
CD multimedia *press button* bluetooth (audio) *press button* Your iphone * right arrow* konfigure unit *press button* check audio then ok and it will work. My idrive is in swedish mode but here som photos.
      11-03-2010, 04:30 AM   #16
krell
14
Drives: F11 520D
Tried in last night and it worked perfectly!
Thanks for all your help.
      11-04-2010, 03:37 AM   #17
SAuchterlonie
Drives: BMW 520
@Harvest: Does this work with just the standard bluetooth in the 520 or does it require one of the other options?
Simon
      11-04-2010, 06:49 AM   #18
sheppie_hill
Drives: BMW F10 520d
*New member, first post*
I have a September build 520d with none of the smartphone integration and the standard non Nav idrive and am able to play music from my iphone 3gs via bluetooth but am unable to skip tracks or see the song titles etc.
      11-04-2010, 07:39 AM   #19
SAuchterlonie
Drives: BMW 520
oooohh...might give that a shot then, cheers mate. All control is via the phone, the intergration allows the use of BMW incar controls.
Simon
      01-21-2011, 10:47 AM   #20
roben
Drives: 520d Touring F11
Did anyone get this to work with iPhone 4 and F11? I just got my 520d F11 from my dealer and I did all the steps above. I get the option to choose the BMW or iPhone but there is no sound when choosing the BMW.
      01-23-2011, 06:22 AM   #21
roben
I bought a cable and connected the iPhone. It worked with poor audio quality. However, by doing this it seemed like I activated the aux input and the bluetooth audio now works as a result. With good audio quality.
      01-25-2011, 01:36 PM   #22
Headspun
Drives: Lexus RX400H
iPhone4 Cradle
I am expecting my F10 (with professional media package as one of the options), in the next 2 weeks.
I'm just wondering if the iphone4 cradle is available yet, as I prefer the idea of click 'n play to messing about with white wires etc?
5post
