best bang for the buck mod?
11-01-2010, 08:37 PM | #2 |
Moderator
618
Rep 10,855
ZSP?
Extreme performance non-rfts. BMW Perf suspension. M3 control arms.
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
11-02-2010, 01:16 PM | #3 |
475
Rep 13,583
Drives: JB E92 335i
What are the goals that you have for your car? Are you looking for something that's height adjustable or are you okay with an aftermarket shock and spring combo? If you're looking for something that's going to be comfortable for your daily driver I would recommend for you to check out the KONI FSD w/ the Eibach Pro Kit Lowering Springs.
KONI FSD (frequency selective dampers) are a must for fine tuning your BMW's ride, and handling capability. KONI FSD adjusts damping automatically, so there is no need to manually adjust the shock absorber. These shocks replace OEM shocks and actively controls stiffness, and dramatically improves handling. KONI revolutionized shocks, with the first ever adjustable shock. It comes as no surprise that KONI remains the market leader in shock absorbers. Pair these shocks up with some Eibach Pro Lowering Springs which provide a slightly more aggressive and raked stance than your stock suspension while still maintaining a comfortable ride. On average Eibach Pro Lowering Springs will lower your vehicle 1.2" in the front and 1.0" in the rear, providing for a lower center of gravity and improved handling. Pro Springs feature more control than that of the OEM springs, but are still comfortable for daily use. Eibach Pro Springs are an excellent choice for street and occasional track use. I'll shoot you over a PM with more details! - Alan |
11-02-2010, 03:45 PM | #4 |
20
Rep 362
**********s, What's the difference between the regular Koni that you are selling vs Koni FSD (in simple words)?
and how would you rate Koni FSD + Eibach vs Koni FSD + H & R? Thanks |
11-02-2010, 04:09 PM | #5 | |
475
Rep 13,583
Drives: JB E92 335i
The H&R sport springs provide a slightly more aggressive and raked stance than your stock suspension. H&R Sport Springs will lower your vehicle an average of 1.3" in the front and 1.2" in the rear for a lower center of gravity and improve handling. Sport springs feature more control than that of the OEM Sport spring, but is still comfortable for daily use. 2) KONI FSD adjusts damping automatically, so there is no need to manually adjust the shock absorber. These shocks replace your OEM shocks and actively control stiffness, and dramatically improve handling. As your vehicle moves quicker the shock reacts to the movement and the dampening stiffens - so on street driving thats nice and slow - the shock dampening will be comfortable and soft, as you speed up at higher speed the shock will stiffen up and tighten up. Eibach Pro Lowering Springs provide a slightly more aggressive and raked stance than your stock suspension while still maintaining a comfortable ride. On average Eibach Pro Lowering Springs will lower your BMW 330i 1.2" in the front and 1.0" in the rear, providing for a lower center of gravity and improved handling. Pro Springs feature more control than that of the OEM springs, but are still comfortable for daily use. I'll shoot you over a PM with more details! - Alan |
11-02-2010, 04:40 PM | #7 | |
Fast In, Slow Out
40
Rep 586
Relatively sticky tires such as the Dunlop z1 star specs and front camber adjusted to -2° or even -3°.
: Ken
11-02-2010, 04:57 PM | #8 |
406
Rep 3,879
You can get coilovers for not much more then the Koni/Eibach combo, which is a real boost to suspension and overall car performance. Coilovers are the best option for those who want to set their own ride height and have the ability to change ride stiffness also.
11-02-2010, 06:08 PM | #10 |
406
Rep 3,879
Shock/springs or coilovers first. There is a lot of labor involved in installing the rear swaybar, so overall cost would not benefit as much.
11-02-2010, 07:11 PM | #13 |
Freight Dawg
104
Rep 2,103
Unstaggering the tires if you have ZSP. Major difference. Or get coilovers that match your tire stagger.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors |
11-08-2010, 12:51 PM | #16 |
70
Rep 441
how much buck? I recently installed the short shifter (just the shifter, not the kit, kept my stock boot and m-tech shift knob). $83 from Tischer including shipping - every shift is noticeably shorter and SO much more fun.
In the bang-for-buck factor, this wins for me.
2009 E90 328i Montego Blue, Black Leather, 6MT, ZPP, Logic 7, HD radio, CA, fold-down seats, PDC. ED pickup 6/12/2009 mods: Koni FSDs, Eibach Pro's, Sport/Heated Seats, BMW Perf. short shifter, M-tech shift knob/e-brake handle/steering wheel, split armrest, black grilles, 50% tint, 3M clear bra. |
11-08-2010, 01:25 PM | #18 |
30
Rep 468
I'm with him.
The geometry and design of the stock style suspension is not good for lowering with springs. If you want to lower the car your best option is coilovers. (although which ones is a whole other debate) If you are looking to have the car handle better, the two best things to start with are better tires and a good performance oriented alignment. |
11-12-2010, 06:19 PM | #19 |
17
Rep 251
When is the best time to change your OEM shocks/springs? Should I drive my car for a little bit, wait till the shocks are more worn out then replace them, or replace them right away?
11-13-2010, 09:42 AM | #20 |
65
Rep 1,705
best bang for the buck is without question better and square(same/similar front to rear) tires when you need new tires (technically no cost!). Second is probably m3 lower control arms and a proper alignment (about $300 total)
11-16-2010, 03:28 PM | #21 |
476
Rep 1,191
Drives: 2009 BMW 328i Wagon
11-16-2010, 05:00 PM | #22 |
1821
Rep 5,337
High Performance Driving School.
Give it 3-5 schools, you'll make a 328i run circles around a heavily tuned 335i on the track driven by a noob.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
