      10-29-2010, 08:01 PM   #1
dragon1761
dragon1761's Avatar
83
Drives: 128i SGM 08; 328i AW 14
DME module
Can someone explain to me what DME module is or does? i have DME module failure.
      10-29-2010, 08:24 PM   #2
bmwmike335
bmwmike335's Avatar
86
Drives: m4
hehhhh? DME is the control unit is ur engine control/computer housing unit. it is what your car basically functions on. its located inside the engine bay, on the passenger side, in the top corner. you have to remove various peices in order to get to the plastic white box that holds it. there bunch of wires and clips and connectors.
how do u know u have a dme failure?
2015 ///M4 2006 525i
2008 335i Coupe
2011 1er 6MT ///M-Sport
2013 535i (RIP), 2014 535i (RIP)
2013 e92 M3 interlagos blue
      10-29-2010, 09:24 PM   #3
Dackelone
European Editor
Dackelone's Avatar
Germany
10523
Drives: N54 e82
Yes, the DME is the "Digital Motor Electronics".
Most cars also have a DME relay that powers up the DME or ECU or ECM depnding on your terminology lingo. DME relay or module.
IF you are getting a code for this relay perhaps you should try swapping it out with a new one. Or one from a friends car.
Btw... Google is your friend!
What Is a DME Relay? --->
http://www.ehow.com/about_4691046_what-dme-relay.html
      10-29-2010, 09:51 PM   #4
dragon1761
dragon1761's Avatar
83
dealership confirmed it. SA said they worked with BMW NA on my car. Im sure they know what they are talking bout cause that thing is not cheap. Almost died with this issue. It shuts down the power in the car to 20mph. I had to quickly get off the freeway to avoid getting killed right after work when traffic is crazy. I had to put put put my way to the dealership.
      10-29-2010, 09:51 PM   #5
dragon1761
dragon1761's Avatar
83
thanks
      10-29-2010, 09:58 PM   #6
Dackelone
European Editor
Dackelone's Avatar
Germany
10523
Drives: N54 e82
Something interesting I just remembered from my VW days...
On the Golf/Jetta III's and IV's... they had a "power supply" relay. Basically a DME relay. When that relay would go bad... when the tech would would the faults stored in the OBDI and OBDII cars... there would be none. When that power supply relay( and maybe with a DME in our car?) it would wipe the ECU memory.
Someone with a BT scan tool might wanna look into that!
But first we need to find out where the relay is at. I know on my old E36 car that car had three DME relays! All next to the fuse box.
      10-29-2010, 11:04 PM   #7
bmwmike335
bmwmike335's Avatar
86
Drives: m4
where you the guys talking about ur issues with ur tire pressure light?
if you are, maybe this DME is creating bugs and resulitng in your tpms to throw off the code?
thats crazy, thats like the HPFP symtoms lmao. car just boom slows down.
as long as its under warrenty.. ur alllll good
2008 335i Coupe
      10-29-2010, 11:09 PM   #8
dragon1761
dragon1761's Avatar
83
now you know why i want to get rid of it. I had issues with the car shaking at high speeds as well. Not sure what the cause of that is either. Its brand new and never had an accident yet it feels like its salvage. Addressed it to the dealer they said they could not reproduce the situation. Now i have this light on.To make it worse its my first car let alone my first bmw.
      11-04-2010, 11:39 AM   #9
bmwmike335
bmwmike335's Avatar
86
Drives: m4
That sucks dude. It seems like it's prolly a mechanically faulty built car and has issues. Try sticking with it n see if u can get a cash settlement out if it. If ur going to suffer the annoyingness and constant headache of the problems and BMW is going todo anything you might as well grt some cash in return. See a lemon lawyer or call them up. It's a lease right ?
2008 335i Coupe
Search this Thread:
Advanced Search
1addicts
