e90 325i Engine Vibration
01-25-2007, 07:48 PM | #1 |
Rep 14
I have 2006 325i which seems to have significant engine vibration which can be felt through the clutch pedal and also the gearlever. It's noticable across the rev-range and isn't very pleasant. It doesn't seem to be getting any better with time (I am past the break in period). In general the engine runs rough. Another aspect I have noticed is that as I lift of the throttle you can feel the gearlever move.
Anyone have similar issues? I'm concerned that possibly one of the engine mounts is not in great shape, or that I may have some sort of an issue with a plug or injector. I've had the car looked at twice by the dealer, and they insist it is normal. Put it this way, it's more akin to a colleague's Golf Diesel than my previous car, and E46 323i. Thanks for your help. |
01-25-2007, 10:46 PM | #2 |
99
Rep 990
I have a similar issue, but different cause I think. My car vibrates a bit too, with it being noticeable through the gearshift especially. However, if I put the car in neutral and rev the engine, it's smooth as silk. Hence I am thinking it's the wonderful tranny. It too has been getting worse over time. When the car was new, acceleration felt like a turbine. Now I feel it. Am not a happy camper about it.
BMW : Sine qua non
Mods: Blacklines | Rear Seat Power Outlets | Rear Fog Lights | Ashtray Garage Door Opener |
01-26-2007, 10:20 AM | #5 |
Rep 14
Thanks. I booked my car in for service next Thursday. Will get them to look at it (again). My experience has been that they usually plug the car into a computer, and unless it says anything is wrong, they won't be able to find anything.
Had an issue with a brake failure on my E46 323i almost 2 years ago. I took it in, they could not replicate the problem, so they replaced the front disks ($1000). They also wanted to replace the traction control computer ($1000) as this was registering a fault. I did not agree to that expense as I believed the problem was with the brakes. I picked up the car, it still felt wrong - like a brake was sticking. The car would still not roll back on hills, and the right rear wheel would get hot. I returned the car to them and the replaced the caliper (additional $1000). As for the E90, another observation I have is that I am getting a clattery sound at idle. Anyone else have this? |
07-19-2011, 02:27 PM | #6 |
Rep 4
Hi I have the same problem with my 318i.
I have light engine vibrations on my gas pedal & clutch when the car is hot only. I have no idea what it is, the dealer cannot see anything. my1997golf, Did you find anything about it? Thanks Tamir |
