Question for 335d owners
10-25-2010, 03:34 PM | #1 |
Rep 132
Last night my car flashed the DEF (Diesel Exhaust Fluid) warning on the iDrive screen signaling 999 miles till the car won't start. Checked again this morning, same warning. Here's the kicker....
I have 4,580 miles on the car!?!?!? I thought this AdBlue fluid would last until 10-12k. I'm a little worried. Did a search, very few reporting low miles for the warning, especially this low. Most of the problems with the DEF seem related to the X5d not 335d. So I either have a leak, my dealer didn't fill it properly upon delivery or I depleted it over 5 months and close to 5,000 miles...WTF? Anyone else have this issue?
CURRENT:2011 E90 335d LeMans Blue/Oyster-Black
CURRENT:2010 Mercedes Benz C63 AMG Black/Black RETIRED: 2007 E92 335i Alpine White/Black RETIRED: 2004 E46 330i ZHP Jet Black/Black RETIRED: 2001 E46 330Ci Steel Grey/Black |
10-25-2010, 04:13 PM | #2 |
Resident Diesel Junkie
56
Rep 1,070
Have you had your software updated? There was some kind of glitch with the original software that would cause phantom error messages, including headlights being out when they were working fine and the Urea being low when it wasn't. That seems like the most likely culprit; no matter how hard you drive, you won't go through an entire tank of Urea in less than 5,000 miles.
10-25-2010, 04:24 PM | #3 | |
Rep 132
10-25-2010, 04:54 PM | #4 |
3596
Rep 10,358
There's always the chance they didn't do a complete fill at the factory. With your low miles it would be very hard to burn through that much DEF. I'd damn near say impossible.
10-25-2010, 07:45 PM | #5 |
Rep 1
Chips,
We had the same symptom in our 2009 335d, at about the same mileage. We were, unfortunately, more than 999 miles from home when the DEF warning came on. We found the nearest dealer, and they added less than 2 liters of DEF. After purging and refilling the system a few times, they determined that the DEF quantity sensor had failed. Good luck... |
10-25-2010, 07:59 PM | #6 | |
Rep 83
10-25-2010, 09:26 PM | #7 | |
56
Rep 1,070
Such phantom codes are symptomatic of the software glitching, the most common symptom being the SES light coming on for no apparent reason, but as in my case other fault codes may also appear for no reason, including the low urea warning. Like I said, it's highly unlikely for his Urea to actually have run out in such a short time frame. |
10-25-2010, 10:28 PM | #8 |
63
Rep 267
I had the same problem @ 8,000km. It was a false alarm, went away on its own a couple days later. Had my software updated when I went in to the dealer for EGR issue. Last week I had my first service and it said they filled about 9.5 liters of DEF.
10-26-2010, 05:36 AM | #9 |
Rep 83
EVTee, How many miles did you have at time of service? E90 Active tank is 7.4L and Passive 12.7L at service; does the invoice indicate they filled up both tanks, just wonder?
IF there is DEF issues it's simply related to the fact that tanks were not filled properly from the start or the re-circulating pump is not working right.
10-26-2010, 01:00 PM | #10 |
35
Rep 188
Buy a container of BMW DEF fluid from the deal @15 bucks.
It has the correct filler nozzle to insert into the filler tube. Keep it in the trunk for emergencies. |
10-26-2010, 01:36 PM | #11 |
34
Rep 173
I didn't get any errors pre or post-software update. I looked at the receipt to see if I could tell how much AdBlue they topped my tank up with (6800 miles) but it didn't say.
Having a spare bottle at home for $15 seems like a good idea....saves a dealer visit. |
