Camber and toe settings for the road track?
10-18-2010, 12:54 PM | #1 |
12
Rep 178
Hey guys, I have Koni FSDs and Eibach prings installed and woul like to get recommendations for front and rear camber and toe that works well for the occasional track day. FYI, I don't have camber plates in the front and I've got the stock end-links in the rear. E92 09 335.
Also, I've read that a bit of negative camber can be squeezed out of the front. Is this true? I've noticed the strut tower is slotted..... Ideas for the occasional weekend warrior?
JB4 FTW
10-18-2010, 01:14 PM | #2 |
1821
Rep 5,337
Occasional track? OEM alignment settings. I didn't start seeing a lot of unfavorable camber wear on the tires until about half a dozen track events a year, and it didn't REQUIRE track specific camber settings until I've got about 50 days on track under my belt.
10-18-2010, 01:58 PM | #3 |
68
Rep 1,432
You need to remove the alignment pin in the top of the front strut. You drill it out then you move the strut in the slotted holes to adjust the camber. You will get almost as much negative camber as with installing m3 wishbones, around -0.8. It is still very reasonable and modest for a daily driver. This simple mod helps to fight the understeer.
10-18-2010, 05:12 PM | #4 | |
12
Rep 178
JB4 FTW
