10-16-2010, 08:54 PM | #1 |
86
Rep 712
Golf Tee / Actuator / Flapper mod For 128i??
Hey guys,
is this possible? i looked under and saw some kind of assembly resembling the actuator plug in the 135s but im not sure. any help would be appreciated.. ran a search but couldnt find any specifics for the 128i. thaaaaanks EDIT: note - i have a 2011 model
2015 ///M4 2006 525i
2008 335i Coupe 2011 1er 6MT ///M-Sport 2013 535i (RIP), 2014 535i (RIP) 2013 e92 M3 interlagos blue |
10-16-2010, 09:42 PM | #2 |
Vrooom :)
313
Rep 2,602
yup it is possible. I have it on my 128 2009. I just used a zip tie : ).
2014 C7 Corvette Stringray - Laguna Blue - NPP Exhaust - Competition Seats
10-16-2010, 09:44 PM | #3 |
doppelkupplungsgetriebe
11
Rep 118
I did that mod on my car, should be the same for the 128i.
http://www.realoem.com/bmw/showparts...67&hg=18&fg=20
10-16-2010, 10:13 PM | #4 |
86
Rep 712
cant seem to find what im supposed to take out or tie or what.. god this was so much easier in m e92.. i just unplugged a little plug in the trunk.
10-17-2010, 12:47 AM | #5 |
Vrooom :)
313
Rep 2,602
i think you can also unplug a little plug in the trunk on the 1 series. I heard it leaves a hidden code however.
10-18-2010, 01:32 PM | #7 |
49
Rep 759
Drives: 128i Coupe 6MT
Just use a zip tie to tie off the vacuum hose that is connected to the exhaust. No need to disconnect it. MAKE SURE YOUR CAR HAS BEEN OFF FOR A WHILE, the exhaust pipe can get really hot.
Should look like this when finished: http://img177.imageshack.us/i/golfmod.jpg/ (Not sure what car that's from, but you get the idea). |
bmwlaguna29.00 |
10-18-2010, 04:20 PM | #8 |
108
Rep 201
Did this to my 128 - it made a significant change (for the better) to the sound, especially under hard acceleration. It only takes 30 seconds to do this mod. By far the biggest bang for the buck mod you'll ever do.
2010 M3 "Edition" model - Monte Carlo Blue/black, (1 of 13) MODS;255/35/19 and 285/30/19 Michelin PSS, Volk G25 wheels, MC V2 GTS lip, Eventuri plenum/intake/airbox lid, M Performance exhaust/spoiler/steering wheel
10-18-2010, 08:37 PM | #9 | |
86
Rep 712
i did the trunk unplugging method to my previous 335 n drove for about 2 years with 0 issues from the car or even the dealer so i stuck with that method. I was just not aware the 128 had that as well. sounds nice, raspy growl around 1-2500 rpm, and when you WOT you really hear the exhaust and no tjust engine noise.
10-20-2010, 12:56 AM | #11 |
86
Rep 712
i posted a post on the DIY gold tee mod section. you have to take out the cover on inside the trunk ont he drivers side. there are two compartments, the far right one, the one closes to the wheel is the one you have to slightly pull out, but make sure u dont rip the carpet padding. you will see a switch, with a metal clip. push the in the metal clip and pull out the top portion of the switch. it will fold the flapper in until you plug it back in.
10-20-2010, 06:44 AM | #12 |
134
Rep 613
Don't want to start any drama with this question, but I'm interested to see if anyone else noticed the same thing I did with this mod on the 128i.
I blocked off the vacuum hose with a barb connector and rubber cap, and put a cap over the acuator as well. It was absolutely airtight. I noticed when I pulled away in first gear, that sometimes the car would stumble for a split second, like it was bogging down. Then it'd pick up as normal. This only happened sometimes, but I reversed the mod to see if it'd help and sure enough, it hasn't done it again since. I can't see how something so far back in the system could affect the engine in this way, but my own 'evidence' really looks like it did. Anyone else run into anything similar? |
10-20-2010, 08:38 PM | #13 | |
49
Rep 759
There's no reason the engine would be bogged down with less backpressure when the flap is open. Now tie up that hose again and enjoy the growl of your engine at lower RPM and under lower load! |
10-20-2010, 08:41 PM | #14 | |
86
Rep 712
part of the reason why im not into the whole "golf tee" wire, zip tie etc etc etc method. the knowledge i picked up over the years with my 335 i understood that i dont want to mess with ANYTHING physically..unless i am replacing the entire thing (intake, exhaust).. also reason why i never did those DIY blow off valve methods..cuz in BMW the smallest little thing plays a huge role in the overall car. i think what you did probably confused and tricked the car, and in low RPMs it was like "wait whats going on" and got clogged.
10-20-2010, 11:05 PM | #15 |
Vrooom :)
313
Rep 2,602
does anyone know if this can affect the brakes/brake booster?
Recently ive been feeling that it takes more pressure for me to hit the brakes, and they don't start doing anything untill i have already 1/2 way pressed the pedal. I've had the ziptie for about 3 months now and the problem has recently started about last week. I heard that the brake booster is also connected to the vacuum pump, not sure what it does though.
10-20-2010, 11:41 PM | #16 | |
86
Rep 712
10-21-2010, 09:27 AM | #17 |
Vrooom :)
313
Rep 2,602
10-21-2010, 09:33 AM | #18 | |
11
Rep 118
That's how my dad explained it to me when I was a kid...
10-21-2010, 01:14 PM | #19 | |
Vrooom :)
313
Rep 2,602
10-22-2010, 03:22 AM | #20 |
12
Rep 249
I tried this mod with a zip tie method yesterday. No lights no performance lost no nothing so far and it took me less than 10 sec. It is just a tiny bit louder I would say about 7-8% more growl at idle and very low rpm? Nothing impressive happen but is it worth doing it? Yes, because it is free.
Currently driving 2003 HONDA S2000
128i | Jet Black | Premium package | Sport package | 18" Style 263 | 6MT | Injen Intake | BMS PowerBox |SOLD |
10-22-2010, 08:09 AM | #21 |
11
Rep 118
Should be. The vacuum comes from the engine intake.
10-31-2010, 07:06 AM | #22 |
134
Rep 613
The flap in my car has become quite noisy after just 5k miles. At least I hope it's the flap or something sounds pretty wrong.
I'm going to redo the mod again and see if it makes the noise go away. |
