Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Tracking, Autocrossing, Dragstrip, Driving Techniques > Changing tires at the track, impact wrenches etc
      10-14-2010, 10:30 AM   #1
kuvesh
kuvesh's Avatar
Singapore
26
Drives: e92 335i juiced
Just bought some new rims with semi slicks and now considering what is the easiest way to change my tires at the track.
Thinking about investing in a cordless impact wrench to reduce the amount of elbow grease.
Have done some research but looking for some advice on the below:
1. What should be the minimum torque rating of the impact wrench required to break loose lug nuts?
I read recommended torque on most cars is +/- 100 ft lbs for tightening the lugs. But some people have recommended impact wrenches need to be at least 200 ft lbs torque to be effective in removing nuts... but that is way higher than the initial torque they are tightened at....
2. Can i use the impact wrench to tighten the lug nuts?
Common feedback is that using an impact wrench to tighten nuts will risk over torque or stripping the lug nut. This risk is probably greater if you have a very powerful impact wrench.
I see Snap-On selling a torque stick which i think can be attached to the impact gun to reduce the risk of over torque but mixed reviews on this.
3. Recommendations on specific brands / models for cordless impact wrenches being used by other trackies
4. Any other advice for changing tires at the track
thanks in advance.
HAMANN FRONT APRON, SIDES, ROOF SPOILER & QUAD DIFFUSER | VORSTEINER VRS TRUNK | CSC3 ON 19” ADVAN RS | BREMBO GT BBK | BASTUCK QUAD | KW V2 | JB3 v1.3s beta | BMW PERFORMANCE STEERING WHEEL | M3 SIDE MIRRORS | M5 SMG SHIFT KNOB | BLACKOUT GRILLS | PARTIALLY SMOKED LIGHTS | WINDOW TINT
      10-14-2010, 12:10 PM   #2
The HACK
The HACK's Avatar
1821
You're going about this the wrong way...
What you really need to worry about, is a light weight aluminum jack. You need something light, and with a handle that can be removed and disassembled to take up as little space as possible since the majority of your available space will now be used to carry full-sized tire and wheels.
As for impact wrenches, I personally would look at the form and weight of the impact wrench rather than it's torque capacity. I went for the lightest 18v cordless I can find (a Hitachi). While it doesn't carry enough charge for me to change out a full set of rims more than twice, it carries enough for a weekend. I carry a 24" long breaker bar just in case the impact wrench struggles to break the nut.
I would love to pick up an Ingersal/Rand or a Snap-On for home use since I don't have air compressor, but at this point, I spend more time working on cars at work and we've got compressed air and an I/R air driven impact wrench.
      10-14-2010, 12:25 PM   #3
jbass524
jbass524's Avatar
99
Drives: 2011 E90 M3
If you have bolts and not studs I wouldn't risk the impact wrench on them. Such a short amount of threads to get through and they are designed to expand. The impact wrench seems like overkill.
With studs there is such a long way to go - and they are tougher then normal wheel bolts - a good impact wrench is great. I always break the nuts loose first though and I only spin the bolts on with the IW. I do final torque with a torque wrench.
I only bought a 14V Bosch so it couldn't loosen and torque the bolts anyway.
Just my reasoning and way of doing it.
      10-14-2010, 12:59 PM   #4
mid-corner fun
81
Drives: F80 M3, '22 X3MC
1. There's no hard and fast rule but my Sears 200ft/lbs impact wrench can't break loose my 88 ft lbs torqued lugs anymore as the battery is too old. It used to be fine though for a year or so.
2. Don't do that please, there's no reason to risk it. Use your extended 17mm adapter to turn in-place, then use your torque wrench to tighten to spec.
3. Snap-on for worry-free operation (says the person that has to use a breaker bar because he thought snap-on is overrated)
4. invest in a low-profile jack and also 2 jack stands, you'll need them.
      10-14-2010, 01:03 PM   #5
zsapphire7
zsapphire7's Avatar
104
Drives: 08 e92 M3
where did u get it and are there other choices ? im shopping around for an electrical one . So many times would it have been useful..
      10-14-2010, 01:08 PM   #6
jbass524
jbass524's Avatar
99
Drives: 2011 E90 M3
I got it on Amazon for $156.00. Comes with 2 batteries, charger and a case. I love it. It's a little more expensive now: http://www.amazon.com/Bosch-22614-14...=pd_ys_iyr_img
      10-15-2010, 07:10 AM   #7
kenneth
kenneth's Avatar
125
Drives: 335i Sedan
I do not track as often as most folks in here, but since I have 3 cars and 3 sets of winters, I do lots of wheel changing in a year.
So I have:
24" Torque wrench
24" Break bar to loosen nuts
Light aluminum low profile jack, with removable handle bar
18V Impact wrench
I wouldn't recommend using the IW to loosen the lugs/bolts. For one, it puts lots of stress on the lugs/bolts. Second, you wouldn't have enough juice to undo 20 of them.
I might get a wheel studs/nuts kit when I start tracking more often, but for now I am ok.
A little trick I have to rotate the spare set of track wheels/tires, is to mark the carry-on tote bags as FR, FL, RR, RL. After each track event, I put the wheels/tires in the appropriate tote bag for the next event. e.g. FR Wheel I used for an event, I put in the RR tote bag and so on!
SB, Terra, 6MT. Only a few mods here and there.....nothing extreme!
      10-15-2010, 10:24 AM   #8
The HACK
The HACK's Avatar
1821
What do you suppose dealerships and professional mechanics use then?
      10-15-2010, 12:00 PM   #9
kenneth
kenneth's Avatar
125
Drives: 335i Sedan
It is just an opinion, you may totally disagree with it, that's ok. Just because dealerships/professional mechanics use it doesn't, again IMHO, make it less stressful for the nuts/bolts. Same folks won't be using a torque wrench either.....
      10-15-2010, 03:34 PM   #10
The HACK
The HACK's Avatar
1821
Every mechanic I know use a torque wrench to tighten a lug nut/bolt.
I also don't know a single mechanic or professional that would hesitate using an impact wrench on a lug nut or bolt to loosen. What puts MORE stress on a bolt or nut is the actual tightening process, whereby the threads are stretched to provide the actual clamping force. Loosening it via impact is actually far less stressful to the nut/bolt than actually tightening it with a torque wrench.
I don't care if you agree or disagree. I'm just merely point out that opinions not grounded on facts, are just wife's tales.
      10-15-2010, 04:14 PM   #11
kenneth
kenneth's Avatar
125
Drives: 335i Sedan
It could well be wife's tales, and I also don't want to argue. From my perspective, rightly or wrongly, an impact wrench does just that, it loosens or tightens by impacting the head of the bolt with twisting force. Twisting itself might not be damageable if done with constant smooth force, but hitting repetitively the head with force is what I have a problem with, not if it was done only 1-2 times a year. But if you track many times a year......
I know of NO mechanic, professional or otherwise, in our region who uses a torque wrench thereafter to torque to spec. They basically tighten with the impact wrench, no torque check. For that I envy you folks!
      10-25-2010, 04:07 PM   #12
swartzentruber
30
Drives: 2011 E90 M3
I sort of accidentally ended up with a solution that I think works pretty well for me. I just use an 18v Dewalt drill with a bolt attachment. I use a small breaker bar to loosen, and a regular torque wrench to finish torqueing, and with proper settings of the drill, you won't risk overtightening. I purchased the drill recently for track use, not realizing the normal thing was to use an IW, but after changing wheels several times this way, I've been pretty happy with this method. Unless there's an issue I'm not seeing, I'm surprised more people don't use this method.
2011 Jerez Black/Fox Red E90 M3 DCT, ZCP, ZCV, ZCW, ZP2, BMW Apps
2015 Golf R
      10-30-2010, 04:47 PM   #13
ChiDiddy
50
ChiDiddy's Avatar
19
Drives: pop smoke
DeWalt Impact w/ battery, ALuminum Jack with at least 1 jack stand (for safety), and torque wrench.
Loosen with impact, LIGHTLY tighten with impact or hand tighten, then torque wrench it.
      10-31-2010, 09:24 PM   #14
BrianMN
114
Drives: 4 Door Family Sedan
I've got these two:
http://www.makitapowertoolsonline.co...ch-BTW251.html
http://www.makita.com/en-us/Modules/....aspx?ID=24056
These are by far my favorite tool purchase recently. The 1/2 inch is great...it can't break loose dealership-tight lugs, but plenty strong for my half tight lugs. I can't remember the last time I've torqued down lugnuts on my own vehicles (obviously always on others' vehicles)....just get them moderately tight with a 1/2 inch ratchet. Personally I see no reason or benefit for torquing the lugs with a 9 foot breaker bar.
