question for those with lowered coupes only?????????
10-12-2010, 07:54 AM | #1 |
162
Rep 2,007
after lowering your cars did the headlights point down? and if so how did you fix it?
E92s only please, i've already searched for this fix yet i only find answers for the sedans that have that screw on the headlamps but i cant seem to find the damn screw on my car. thanks guys. |
10-12-2010, 07:56 AM | #2 |
DENY THE WORLD THAT SURROUNDS YOU
505
Rep 35,580
Drives: JB 33ZERO
Of course they do, you need to adjust them up. You asked for E92 "only" for obvious reasons as I do not know how to adjust the E92, but for the E90, it is very simple. Just need a phillips head screw driver.
Eurocharged V5 | ROW's / CC Delete | K&N's | H&R Springs | Single Fin G.B. Grill | Mode Carbon Diffuser | JBSpeed CF Spoiler | Arkym Style CF Splitter | CF Mirror Caps | 5% Tints | 12mm Spacers | |
10-12-2010, 10:15 AM | #3 |
162
Rep 2,007
10-15-2010, 03:12 AM | #4 |
No 55mph
1622
Rep 8,476
Shouldn't need to adjust anything if you have the self leveling headlights...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
10-15-2010, 03:32 AM | #5 |
33
Rep 812
10-15-2010, 03:34 AM | #6 |
No 55mph
1622
Rep 8,476
Well, then in that case what ever was done to lower the car must have affected the self leveling linkage, other wise what would be the use of self leveling lights if they don't self level?
10-15-2010, 12:36 PM | #7 |
148
Rep 1,728
Pre-LCI E92 have the same screws on the headlight assembly. I did the same after my coil-over install. I have not verified LCI e92 headlight assembly but I can confirm that the Pre-LCI do have a round cap-looking thing where a Philips screwdriver can fit into.
'11 Space Grey E92 335xi M-Sport (KWv1 Coils | Saddle Brown | Bamboo) (Returned)
'14 Mineral Grey F32 335i M-Sport (Dinan DHP | LED Lights | Coral Red | Hexagonal Aluminum) (Returned) '16 Mineral Grey F80 M3 ZCP |
10-15-2010, 01:15 PM | #8 |
No 55mph
1622
Rep 8,476
For a E9x 2006-2009:
Headlight Aim, Adjusting Adjust headlight aim with correct tire pressures, fuel tank full, and weight of one person (approx 165lb) indriver seat. When adjusting xenon headlights, switch lights ON, then wait 80 seconds before proceeding with adjustment. Do not move or vibrate vehicle during that time. Working above and in rear of headlight housing, use screws to adjust headlight aim: *A Primarily Vertical aim adjustment *B Primarily lateral aim adjustment Adjuster 'A' is behind headlight, under radiator core support, slightly to the left of where the core support bolts to fender with the (2) bolts. Adjuster 'B' is hidden under a plastic plug at the very front of the fender edge
10-15-2010, 06:29 PM | #10 | |
162
Rep 2,007
thanks this is more of what i was looking for, i will check it out in the morning, but i just had the lights adjusted a bit by my dealer. haven't had the chance to check out how much they raised them but if im not happy i'll either adjust them myself or take it back as my SA told me to let him know if i wasn't happy with the adjustments. |
10-16-2010, 09:29 PM | #11 |
36
Rep 738
Drives: G30 530i
thanks for the picture.
I've got the exact same issue with my E92 after Eibachs. It's amazing the difference .4" can do to headlight angle.
G30 530i
