2007 328i audio inquiry
10-02-2010, 07:24 PM | #1 |
Rep 19
I'm looking into purchasing a 2007 bmw 328i sedan. I've read quite a few threads from quite old to current and confused slightly with the audio upgrade stuff.
I'm looking to retain the oem headunit and purchase audio equipment. I really wanted to see if this below would work? I have an amp (mcintosh mcc224) that I was going to use and purchase a set of 4" components for the front doors as well as 4" coaxials for the rear doors. All of this would be tied in using the jbl ms-8. I saw the list of speakers that would fit so will probably purchase the morel dotech ovation and morel tempo 4" drivers for the rear doors. I really don't want to run a sub. Most of my reading showed the coupes to have a sub underneath a seat. Does the sedan have any factory subs? I'm basing all of this off of the base audio equipment not hifi nor anything else. Thanks in advance for any help. Recap: jbl ms-8 mcintosh mcc224 amp Dotech Ovation Comp 4 - Morel 4" Way Component System Tempo 4C - Morel 4" Integrated 2 Way Coaxial Speakers Will this setup work? |
10-02-2010, 10:37 PM | #2 |
1917
Rep 13,109
Which system do you have HI Fi or logic 7
http://www.e90post.com/forums/showthread.php?t=352586
http://www.e90post.com/forums/showthread.php?t=365866 There are lots of examples of systems in the threads in this section . If its the high fi system in and 07 people replace the the speakers under the floors (front seats)with sw8's and the speakers you are suggesting for the doors and add a 4 or 6 channel amp . Adding a processor is an option. The ms8 doesn't have a lot of power out for high end speakers. US 07's have either the 10 speaker hi fi system or Logic 7 Also the 07 system for HI Fi is component pairs for both doors(front and rear doors or rear deck) and passenger underseat speakers. Last edited by ctuna; 10-02-2010 at 11:15 PM.. |
