BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Need help with my alignment
      10-02-2010, 12:52 PM   #1
ctv
16
Drives: T4RV8
lowered my car with eibach pro kit on a e90
what should i do?
      10-05-2010, 01:06 AM   #2
e90pilot
Freight Dawg
e90pilot's Avatar
104
Drives: E90 325i
The rear is fine. WTF is up with the front? You should be -1.5 camber I think. Not sure why you have one at almost 0 and the other at -1.2. The shop should be able to align it. If they can't, you can get some adjustable camber plates to fix that.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors
      10-05-2010, 01:33 AM   #3
kevin@bavarianx
33
Drives: E36 M3
You could try jacking up the front and then loosening the bolts on the strut tower and shifting the strut to the right to get more negative camber. Then tighten everything down again.
      10-20-2010, 04:17 PM   #4
ctv
16
Drives: T4RV8
thanks for the help! it worked!
