Rear brake service light went off at 21k miles
10-02-2010, 01:36 AM | #1 |
Rep 29
My 325i is at 21k miles and the rear brake service light is already on. I was thinking about DIY it, but i am a noob at these kind of work. Will it be a hard or easy DIY?
Should i go for all BMW parts? or aftermarket brake pads/rotors? How much do dealer/indy shop charge for rear brake service? Thanks! Last edited by bdbdbd; 10-02-2010 at 03:19 AM.. |
10-02-2010, 02:16 AM | #2 |
Freight Dawg
104
Rep 2,103
If you still have ultimate service you can get it done for free. Check they DIY section for instructions. It's pretty easy if you've done brakes before. It's not too bad if you've done them before. The caliper bolts and rotors will be rusted on pretty good. Make sure to get some thread penetrator.
If you don't drive on the track or use brakes a lot, then go with the BMW stuff. Getbmwparts.com has the parts for cheap. Dealer is over $500, and as indy shop might be $300-400.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors |
10-02-2010, 03:26 AM | #3 |
Rep 29
out of warranty. Never done brakes before
These are all the parts that i need? 2x Brake pad :http://www.trademotion.com/partlocat...layCatalogid=0 2x Rotor :http://www.trademotion.com/partlocat...layCatalogid=0 2x sensor :http://www.trademotion.com/partlocat...layCatalogid=0 |
10-02-2010, 04:24 AM | #4 |
Freight Dawg
104
Rep 2,103
Just one sensor. I think the pads come per axel but I'm not sure. Get brake parts cleaner, thread penetrator, and anti-squeek from your local autoparts store. You may not need rotors. If they have a huge lip, then replace them.
--Marcelo
10-02-2010, 03:27 PM | #6 |
Freight Dawg
104
Rep 2,103
Nope it's only on one sensor per axel. I think it's on the passenger side in the back. You'll need to remove 2 screws from fender lining to get to the plug.
--Marcelo
