2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes F10 535d wheel lug nuts torque
      09-29-2010, 12:58 PM   #1
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
Does anyone know what the tightening torque is?
      09-29-2010, 02:13 PM   #2
bobblehead
bobblehead's Avatar
256
Drives: warp speed
Should be 90 +2 or 3 max. - Higher because it's using the M14 bolts vs The E60 (88) M12 bolts
      09-29-2010, 03:24 PM   #3
gatoman39
gatoman39's Avatar
116
Drives: 2011 E92 335 M-Sport
I asked the service adviser who called the technicians who looked it up,and he said it's the same as E60 90 ft-lbs
      09-29-2010, 04:23 PM   #4
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
Thanks guys, but there seems to be an element of confusion here.
Since posting the question I checked the instruction leaflet that was included in the BMW locking lug nut pack for my E92.
It's a general leaflet catering for most models including 3 and 5 series and it's issued by BMW.
It clearly states the following:
120+/-10 Nm for all versions in M12
140+/-10 Nm for all versions in M14
For reference 120 Nm = 88.5 Ft/Lbs, 140 Nm = 103 Ft/Lbs. Going by that, 90 Ft/Lbs doesn't reach the lower end of the tolerance band.
I get a bit anal about things like torque settings and tyre pressures, so I'll call my local dealer in the morning and see what they come up with - I'll let you know.
      09-29-2010, 04:29 PM   #5
gatoman39
gatoman39's Avatar
116
I got confused by the exact same thing, when I bought the wheel locks. I don't know what M12, or M14 was in reference to. So I asked the SA, and that's what I went with. I'm with you, now that you mention it that did bother me when I first changed the wheel locks, but I since put it out of my mind. Thanks for waking up the demons. Seriously, though, let me know what he says, in return I will call a couple other dealers in SoCal, and let you know what they say.
      09-30-2010, 10:01 AM   #6
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
My dealer said 120 Nm, which contradicts the wheel lock instructions. However, although the F10 bolts are 2 mm thicker, they do have a finer thread and would therefore take a lesser torque pro-rata to the diameter.
I torqued mine to 125 Nm, but I'm not completely happy so I'd be interested to hear what what your dealers say.
      09-30-2010, 10:26 AM   #7
HighlandPete
6659
Drives: BMW F11 535i Touring
I'll stir it a bit... don't forget the issues of dry vs. wet or dry film lube.
Just a thought, have the latest M14 bolts changed from the thread pitch of earlier applications. That could answer the value issue.
HighlandPete
      09-30-2010, 10:59 AM   #8
gatoman39
gatoman39's Avatar
116
I have contacted 3 separate dealers:
1 service department: 90 ft/lbs
1 parts department: 90 ft/lbs
1 service department: waiting to hear...
      09-30-2010, 05:02 PM   #9
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
HighlandPete
Yes, I'm well aware of the differences between dry, wet and dry-film torque values. I spent my entire working life in aviation engineering and even with the abundance of technical manuals, you'd still see instances of 'I-know-better'. Applying oil or grease will amplify the applied torque by around 30%; dry-film 50%. Always best to .
I don't know what the thread pitch of earlier M14 bolts was, but these are finer than those on the E92 M12's, which would indeed account for the lower setting.
I just wish BMW would include this in the handbook.
      09-30-2010, 10:01 PM   #10
gatoman39
gatoman39's Avatar
116
Crap dude, a Service Technician just emailed me in response to me inquiry:
He told me it's 140 Nm = 103 Ft/Lbs. Which is contradicting what I have heard at 3 other dealers. I emailed him back to double check.
FYI this if for a
2011 535i Sport
      10-01-2010, 11:56 AM   #11
gatoman39
gatoman39's Avatar
116
OK so the service tech double checked and said 90 Ft/Lbs is the correct spec. I also contacted 2 independent tire shops, and they said the same, so that's what I'm going with.
      10-01-2010, 12:54 PM   #12
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
Thanks for your help; until I hear anything else I'll stick with 125 Mn (92 Ft/Lb) and recheck regularly. I'd rather err on the side of under as opposed to over-torque.
      10-01-2010, 02:17 PM   #13
bobblehead
bobblehead's Avatar
256
Drives: warp speed
103 lb seems very high, so I am right afterall. Anyway, it's better to under torque it than over torque. Bolts might break if over torque.
      10-01-2010, 02:30 PM   #14
gatoman39
gatoman39's Avatar
116
Just as further reassurance, I took all the wheels off when set at factory spec with a breaker bar and they were very easy to remove. When put back on and set at 90, they are equally easy to remove. I set it to 103 ft/lbs just to check and they were much harder to remove versus when I first removed the wheels set from the factory. So I'm going with 90 ft/lbs. Hope this helps.
      11-16-2010, 03:12 PM   #15
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
Bolt torque update.
I spoke with the senior technician at my local dealer, who has kindly sent me a print-off from their maintenance computer.
F10/F11 M14 Bolt torque - 140Nm = 103 Lb/Ft.
      11-16-2010, 06:00 PM   #16
gatoman39
gatoman39's Avatar
116
Bolt torque update.
The humanity! Now you got me all worried again.
5post
