BMW Performance + Suspension ?'s
09-28-2010, 10:25 AM | #1 |
Rep 66
Im researching suspension upgrades and have found very valuable information on this board, thank you to all who have contributed.
Why do I, and so many others, assume the BMW performance parts will "outperform" the aftermarket vendors? Is it because of the BMW label? Do we assume they put millions of dollars into their R&D that they have found the ideal configuration under "normal" driving variables? on to the suspension.... Again, from reading and researching, its seems a quality and popular option to improve suspension is the KW coilover kit. Has any analysis been done in comparing this kit to the BMW Performance Suspension Kit? Obviously, i'm torn between the two. Thank you! |
09-28-2010, 11:13 AM | #2 |
106
Rep 1,428
this is only my opinion and is not fact based, but i believe that it is because the aftermarket caters to many different makes and models. therefore i dont see how they wouldnt mix and match between them. where as a bmw suspension is designed for a particular model with the same components. for instance from my reading and what little understanding i took from it, i had just purchased aftermarket parts to overhaul my suspension. i would be willing to bet that lap times are going to suffer from the "upgrades" that i made. due to the fact that our cars dont have lsd's and the stiffer rear end will loose traction around turns. i chose the items for my own reason i want to feel like im driving a better car, numbers are not important. i think for real performance the zsp setup, as in spring rate, size of sway bars, and the suspension bushings are probably the best for this car.
09-28-2010, 02:35 PM | #3 |
179
Rep 3,923
i drove a bmw performance 335i kitted demo the other day, the suspension was faultless on the road. no rubbing, no pulling, no clonking, no problems with the steering, thats why you buy oem bmw
09-28-2010, 03:11 PM | #4 |
814
Rep 3,953
Even better when you put the M3 control arms on with it.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
09-28-2010, 03:35 PM | #5 |
106
Rep 1,428
if you are like most, myself included, who will never use their suspension to its ability, i would get the kw's. you can lower it as much as you desire, and change it later if you change your mind.
09-28-2010, 04:00 PM | #6 |
Freight Dawg
104
Rep 2,103
The advantage of the BMW performance is not really the performance in terms of grip and balance, it's the fact that will work without issue. Some aftermarket solutions wi have some clunks or rattles on some cars and not others. Some were tuned with different wheels and tires. The BMW performance was tuned with factory wheels with similar weights and runflats with the same width as a stock ZSP.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors |
09-28-2010, 10:07 PM | #7 |
146
Rep 1,922
Drives: E90 335i, E70 X5
i was debating between a very common setup: H&R sport with koni yellow and bmw perf.
ended up i went with bmw perf because it is engineered for the specific car. i had Tein, Tanabe and some other brands suspensions on my previous cars and the first thing i notice that how well the bmw perf suspension can achieve the stock ZSP feel ride during normal daily driving. not anything bumpier than ZSP (maybe just slightly bit) but it improves the handling.
-eric
E90 335i TiAg *STOCK* see my garage for mod list.. E70 X5 SGM *try to stay stock* :/ |
09-28-2010, 10:13 PM | #8 | |
106
Rep 1,428
09-28-2010, 11:27 PM | #9 |
146
Rep 1,922
i ordered them separately, i got the Perf struts kit and a set of Perf yellow spring kit from tischer, but i did not get the front sway bar tho.
-eric
09-29-2010, 10:07 AM | #10 |
814
Rep 3,953
You need the bar. It makes a huge difference.
09-29-2010, 03:53 PM | #12 |
146
Rep 1,922
+1, according to tischer, the fsb comes with Perf suspension is 26.5mm, and stock ZCP fsb, also the stock E9x M3 (exclude E93) fsb is 26.5mm.
-eric
09-29-2010, 09:20 PM | #14 |
106
Rep 1,428
the fact that bmw has different spring rates for sedan or coupe, and manual or automatic and every spring has a strut to match that alone tells me that there is more engineering in bmw parts, o.e. or performance. i doubt the struts and shocks are any different between the h&r touring and sport cup kit, sure they work but there's got to be a compromise somewhere.
09-29-2010, 09:27 PM | #15 |
106
Rep 1,428
i thought the new performance suspension came with a rear sway bar and the front was retained. the performance rear is 14mm instead of the sport pack 13mm. also ive read that the sport pack front sway is 26.5mm at the thickest point, maybe the m3 sway is 26.5mm all the way across.
09-29-2010, 09:57 PM | #16 |
146
Rep 1,922
the previous suspension kit came with the rear sway, but the new generation suspension kit comes with front sway now. when i ordered mine, even tho it is separate orders, they still need to verify my vin so they can match up with the right springs.
-eric
09-30-2010, 08:16 AM | #17 |
814
Rep 3,953
Same diameter but stiffer with different angles. When I had the old and new side by side I was like "that can't be right".
10-02-2010, 01:27 PM | #18 |
76
Rep 1,644
Is it possible to install just BMW Performance springs on a non-ZSP 335i?
Former car
2011 BMW 335i Step - Montego Blue / Chestnut Brown |
10-02-2010, 01:38 PM | #19 |
106
Rep 1,428
of course it is possible, i dont think anyone could tell you the outcome with any certainty unless they have that setup. i doubt many do, and i doubt many would recommend it.
10-02-2010, 03:16 PM | #20 |
179
Rep 3,923
its best not to mess around just fit the complete suspension from bmw and you know it will do what it says on the box with no issues. i recently drove a bmw 335i demo car with the suspension fitted and i thought it was perfect for the road, it hardens up the faster you go and it actually rode better than my car with the m sports suspension so im having mine changed on monday. it will be cheaper in the long run as well.
10-04-2010, 03:22 PM | #21 |
141
Rep 1,423
Drives: '07 N54 e90, '10 N54 e93, TBSS
the stance of the HR Sports is excellent, stock ZSP shocks get bouncy on dips. Shorter shock is the way to go.
Bought BMW performance shocks to install in hopes of improving the ride. Appears no one has done this combo. If successful it will be the best look, handling, and most affordable setup!!
E90 - H&R Touring - M3 Front Arms - Work Genosis GS-1 19x9+30 x10+26 225f 265r stretch - AA FMIC - AR DP - Cobb E30 Map +160rwhp/+200rwtq
E93 - Style 95 - RB Turbo - AR DP - Evolution RW FMIC - PTF E50 +242rwhp/+234rwtq |
10-06-2010, 04:13 PM | #22 |
Rep 13
For you guys that have installed the factory performance suspension does it drop the car lower than ZSP and by how much? I want just a little lower and stiffer. Have had H&R sports with FSD and Eibachs with FSD recommended. Yes I know coilovers are best option but I don't live in a mod friendly area and can't see wasting a day to drop the car off and pick it up. Any input is welcomed.
