shaking under braking, slight steering travel - casues?
09-26-2010, 04:49 PM | #1 |
1309
Rep 6,311
When I brake from say 200kph / 125mph down to say 100kph / 60mph, my steering wheel shakes and there is noticeable play in the steering when I drive at higher speeds (even on smooth roads). It's unsettling as it takes off my confidence when driving fast.
Any ideas what it can be caused by? I have troubleshoot this but no long term fix so far: - full 4 wheel alignment done - tyre pressures correct - wheels are balanced - front rotors and pads are brand new, correct bed in procedure done. - before rotor replacement the shake existed also for a few months Any help guys? What can be causing the shaking if the rotors are new and pretty sure aren't warped.. I'm
997.2
F30.F11.E86.E90.E90.E36 |
09-26-2010, 04:51 PM | #2 |
1309
Rep 6,311
Oh, and forgot to add, may be it's important:
Disclaimer: I hit a sharp gradient change in asphalt pretty fast which bent the stabilizer rod on front right. Tyre bubbled, I've put a spare tyre with 1mm less thread (same model, same thread). By now the shoulder of the said tyre is worn out to bold - cant recall how quickly it wen but was already there when shaking in the wheel began. Pressures are all ok. I wonder if the steering play, shake, and braking are related to this...
997.2
09-27-2010, 01:41 AM | #5 | |
Freight Dawg
104
Rep 2,103
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors |
09-27-2010, 09:03 AM | #6 |
1309
Rep 6,311
it's been replaced, yup. I'm considering to switch over front tyres to rear and see if that will improve things... i run a square setup anyway.
997.2
