Installed ST (by KW) coilovers, car feels a little bouncy when coming to a stop
09-21-2010, 06:12 PM | #1 |
117
Rep 557
Just installed the ST coilovers (exact same components as KW V1s except they have galvanized rather than stainless steel bodies). Overall the ride is definitely firm and handles great, but it feels a little bouncy, both when hitting bumps at speed and when coming to a stop. I thought the firmer springs and shocks would be less bouncy, not more. When coming to a stop I slow down and when I hit a dead stop the car seesaws front to back a little. It's not horrible, but it's definitely noticeable and doesn't seem right. These shocks are not adjustable - according to KW they're set with the ideal balance of performance and comfort.
I'm almost positive my install (DIY) was done correctly, everything is tightened, etc. Any ideas what would cause this or is it just how these coilovers ride? |
09-22-2010, 09:12 AM | #3 |
37
Rep 2,084
Even brand new rear subframe bushings will bounce over bumps after you install stiffer springs. M3 bushings will solve it, but the install is difficult and road feel will increase.
09-22-2010, 10:17 AM | #5 |
46
Rep 967
It's really funny you mention that, because I thought I was the only one with that problem!
It's something that I haven't thought about for a long time, I guess because I got the m3 rear subframe bushings installed, but it used to drive me crazy. If you're thinking about doing the subframe bushings, which is certainly not a mod for the faint of heart, I say go for it! I have no regrets, the car feels great.
| PROcede Rev3 | Vishnu Meth | DCI | BMW Perf. Exhaust | AR Coated/Catless | CP-E FMIC | Quaife | |
09-22-2010, 12:19 PM | #6 |
117
Rep 557
The car has 35K miles, I would hope the bushings aren't that worn. I won't be doing M3 bushings - I don't track the car and we're a one car family so ride comfort is more important than precision handling.
One thing that did occur to me is that I reused the stock nut/foam pad/washer on the top of the shock (the one that you tighten from inside the trunk). It just looked more substantial than the new KW supplied one. However I wonder if that foam pad that's attached is allowing a little more play at the top of the shock and causing the bounce. Stratplaya - did you reuse the OEM nut or the KW nut? I may try switching that out to see if it helps. |
