stock e92 m3 suspension
09-20-2010, 11:19 AM | #2 |
88
Rep 1,404
Plenty of discussion on this topic. Perform a search and you'll find plenty of information and pics. Short answer to your question is yes.
Name: Blanca | 07 E92 | AW-Blk | ZSP | Alcon BBK | M3 Bits | VM RR Links | Koni | UUC Sways | V5 | Dinan CAI | ETS IC | Fge DV | ER CP | Cyba | Raden. Exh | Mod Step | Trunk Drawer | Perf LED Wheel | Illum Dr Sills | IS Shifter | Parrot | Philps D1S | 6000k fog | MTECH RR | CSL Trunk | Aero | Roof Spoiler | PSS on BBS RS-GT 19s
09-22-2010, 06:53 AM | #4 |
12
Rep 137
hi thanks for repying. no i am not trying to fit them on 335 at but just on the 325 i se. the front looks the same but the rears luk different to be honest. because on my 325 the springs r separate to the shocks whereas the m3 coilovers the rear shock and springs are complete. i may be wrong and sorry guys i did try searching google and all i had no luck hense i asked for help here.
09-22-2010, 07:03 AM | #5 |
12
Rep 137
would this even be a decend mod as i want to go lower than the standard on my e92. sorry guys i cant find the descusion on this on google or on here.
09-22-2010, 04:27 PM | #6 | |
88
Rep 1,404
http://www.trademotion.com/partlocat...47&startrow=76 Nomenclature: Part number: Price: OEM BMW E9x M3 Aluminum Rear Guide Rod Set PKE9XM3RGUIDE $465.00 OEM BMW E9x M3 Aluminum Rear Wishbone PKE9XM3REARWISH $240.00 OEM BMW E9x M3 Front Sway Bar Kit PKE9XM3FSWAYKIT $215.00 OEM BMW E9X M3 Rear Sway Bar Kit PKE9XM3RSWAYKIT $175.00 OEM BMW E90/92/93 M3 Front Control Arm/Tension Strut Retrofit Set PKE9XM3ARMS $405.00 or OEM BMW E9X M3 Suspension Component Kit PKE9XM3SUSPENSION $1,825.00 Check this site out. You’ll notice they have been around for quite some time
09-22-2010, 04:46 PM | #7 |
88
Rep 1,404
Ok Parminder,
Here are some links on the M3 suspension swap discussion. Also, I would research if all of your suspension components are compatible with your car by a qualified local tuner or service tech. http://www.e90post.com/forums/showth...=m3+suspension http://www.e90post.com/forums/showth...=m3+suspension http://www.e90post.com/forums/showth...=m3+suspension http://www.e90post.com/forums/showth...=m3+suspension http://www.e90post.com/forums/showth...=m3+suspension I hope this helps with your future endeavors. I think, for your car's suspension, this M3 kit may be a bit overboard. There are several types of lesser modifications that don't need to be so drastic. Maybe just firmer shocks, lower springs, and/or sway bars are all you need. Just a thought.
09-23-2010, 02:55 AM | #8 |
12
Rep 137
hey thumperx thanks for your detailed reply a lot helpful. the only reason i was going for the m3 suspension was due to the fact that i was getin it for less than 100 dollars so thought might just be a straight swap, now i see why its going cheap. well i think i am just gona go for some good coilovers which will fit the 325 straight on instead. thanks for your help
