Installing back on the OEM suspension
09-17-2010, 05:47 PM | #1 |
76
Rep 1,548
Hi guys,
Is the washer in the picture part of the OEM suspension? My FK coilover went back and I installed the original back on with the washer in the picture goes in between the Upper Strut Mount and the car frame. Im getting noises when going over the bump and the car now sit higher. Thanks |
09-17-2010, 06:06 PM | #2 |
1821
Rep 5,337
http://www.realoem.com/bmw/showparts...16&hg=31&fg=10
Doesn't look like any part in the OEM diagram is similar to the washer you're pointing to. |
09-17-2010, 11:03 PM | #3 | |
34
Rep 210
09-18-2010, 12:15 AM | #5 |
34
Rep 210
Funny, my 2008 E92 had the paper washer/gasket but no flat steel spacer in the same shape of that washer/gasket... I also show no such part in the exploded diagram in my Bentley manual.
09-18-2010, 04:16 AM | #6 | |
76
Rep 1,548
09-18-2010, 08:56 AM | #7 |
Rep 195
That part was not present on my e90.....it looks like an aftermarket universal type part with all of the holes and I am guessing it was for use only with the coilovers...
09-19-2010, 02:33 PM | #10 |
1821
Rep 5,337
#6 is a wafer thin gasket type ring if I'm not mistaken, not a thick spacer like part.
09-19-2010, 02:45 PM | #11 |
34
Rep 210
09-20-2010, 06:12 AM | #13 |
201
Rep 3,328
Drives: Coding: Desi4life10@gmail.com
That is an OEM spacer.
I have that on my car as well. The holes on that spacer are there in case you need to make adjustments with the alignment pin. That spacer goes with the car and not the aftermarket suspension |
09-20-2010, 12:55 PM | #14 |
117
Rep 557
I have those black spacer rings on my 07 335i, so yes they're OEM.
Speaking of that paper gasket, what is it for? It was a real pain to reuse, getting it seating properly was a challenge when re-installing the struts. Anti-squeak I assume? |
09-21-2010, 04:52 PM | #16 |
1433
Rep 16,628
that part is OEM. some cars have them and some dont. some even have the paper gasket as well. some have nothing. Not sure why BMW did it.
