help needed with lowering
09-16-2010, 08:19 PM | #1 |
14
Rep 211
Hi i own a 2007 335i with sport package and i installed TEiN S lowering spring well the car dropped a lot more than i expected and now the front wheel is pretty much behind the fender which when the car is stopped and i turn the wheel almost a turn and a half the tire is right under the fender.
My wheels are 19x8.5 in the front and 19x10 in the back with 245/35/19 front tires and 275/30/19 back. So my question is how do i solve the rubbing on the back and how about the no space between the tire and fender when wheel is turned, pretty much getting in to my driveway i have to drive very very slow so my front tire doesnt rub on my fender. |
09-16-2010, 08:33 PM | #2 |
Freight Dawg
104
Rep 2,103
You can roll the fenders if you have a sedan. Coupes are a little trickier.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors |
09-16-2010, 09:09 PM | #3 |
14
Rep 211
i have a coupe. My rear looks like i can get around but the front worries me a little because when the wheels turned a little there is only an 1/8 of an inch space between the tire and the fender.
09-16-2010, 09:11 PM | #4 | |
369
Rep 8,693
Drives: 06 330i
09-16-2010, 09:13 PM | #5 |
369
Rep 8,693
Drives: 06 330i
09-16-2010, 09:45 PM | #6 |
14
Rep 211
i see that and i am impressed. what happens to the wheel when you turn and you hit a little bump does it hit the front fender ? and dont forget i am running 19x10 in the rear with 32 offset and 19x8.5 on the front with 35 offset and bigger tires and i think that might be my problem
09-17-2010, 01:50 AM | #7 |
163
Rep 2,979
Drives: 07 SBM E92 335i 6MT
Man...just find someone to roll your fenders...I'm only on H&R sport...my wheel well sits barely above my wheel..and I rub when I turn all the way...I have the same wheel/tire/offset setup you have...
Either that or buy different springs/coilovers.... Those are you choices...or live with the rubbing...
In the process of restoring an 07 335i
09-17-2010, 06:54 AM | #9 | |
369
Rep 8,693
Drives: 06 330i
09-17-2010, 08:31 AM | #12 |
163
Rep 2,979
You can't roll the front? Didn't know that...good to know for the future....sorry I thought I had the exact same setup..I have 235's on the front which is the widest most go on here...especially with a drop...do you have pics?
09-17-2010, 11:56 AM | #13 |
142
Rep 2,900
OP post some pics.
09-18-2010, 12:10 AM | #17 |
163
Rep 2,979
I think you're ok...looks awesome...
09-18-2010, 09:52 PM | #20 |
369
Rep 8,693
Drives: 06 330i
craven i sent you a pm
09-19-2010, 08:01 AM | #22 |
369
Rep 8,693
Drives: 06 330i
no, but to be sure you should be running a 225.
