Hitting the wall with your rear bumper when turning
09-15-2010, 11:38 AM | #1 |
LCI'd
257
Rep 819
Hi guys,
I've always wondered, is it possible to hit something (wall, another car, etc) with your rear bumper, while going forward, and turning? Like this: [Your BMW] [another car] [/////is////] [/////is////] [/////here/] [/////here/] You go to full left lock, and get on the gas (nothing in the way). Is it possible to do this: \Your BMW\ [the other] .\is turning\ [car] ..\and hits \[here] Here is a quick sketch in MS paint: I'm just wondering if it's possible to actually hit something with the overhang of your bumper on a car our size... I can imagine it is probably possible on a bus, etc. Oh, and I mean within normal circumstances (not parking really close to the other car on purpose... i.e. normal room for passenger to get out) Thanks |
09-15-2010, 11:50 AM | #3 |
422
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
Good question actually. Try it and let us know (carefully and slowly, of course).
09-15-2010, 12:00 PM | #4 |
922
Rep 5,538
09-15-2010, 12:06 PM | #5 |
253
Rep 7,089
Drives: '06 AW 330xi
Umm if you think about it, when you drive, your car goes forward (or reverse)....when you turn, your rear tires are still going forward, not whipping to the left or right. They'll always stay in that line.
Unless you can somehow turn your car without the right, rear wheel moving at all....then no, you won't hit the car next to you. |
09-15-2010, 12:08 PM | #6 |
377
Rep 2,982
The only way it is impossible is if the furthest back point of the car is actually the rear wheel/pivoting point. So yes, it's possible, but being that the wheels are pretty far back and the bumper doesn't come off as much as say on a bus or something, it'd be very difficult to hit something in this way. The car you're hitting would have to be like an inch away or something. Also, your turn would have to start from a full left lock to get that rear bumper to swing out immediately. Why the random question? You put a lot of work into this hypothetical scenario haha
09-15-2010, 12:08 PM | #7 |
73
Rep 463
As the car turns, YES, a little bit of the rear bumper will always stick out just a tad. The more rear overhang, the more will stick out. BMWs have very little overhang, so this problem is not a big one.
The sharper your turn, the more of the rear will "stick out". |
09-15-2010, 12:18 PM | #8 |
LCI'd
257
Rep 819
Wow, 7 views and 6 replies, that must be a record! Thanks for the replies... I was just wondering about it, several times... sometimes when making a T turn, it has happened that I have gotten rather close to things, and then I decided to turn immediately, so I was worried about hitting the other car, next to me...
Today, I parked close to a wall, I watched PDC on the iDrive, and again, I decided it would just be easier for full left lock and just slowly get going... well, nothing happened, but it did scare me... since I've been wondering about it I decided to post I assume the turning effect is like this: http://auto.howstuffworks.com/differential.htm I.e. rear wheels are following the front ones, so virtually no chance of hitting anything? |
09-15-2010, 12:41 PM | #9 |
Rep 47
Again, at normal parking distance between the two cars, no possible way of hitting the car next to you turning at full lock if you're are turning the opposite way and there is no car parked in that space you are turning towards.
09-15-2010, 01:28 PM | #10 |
[]D []-[] []_[] []< []\[] []_[] ']['
27
Rep 418
Drives: 335i Convertible/Le Mans Blue/
The swing on a tractor-trailer can be wide because of the distance from the rear tire and the back corner. The swing will always be a function of the distance from the outside tire to the outside back corner and will vary from car to car. A station wagon or pickup truck would be the extreme while a car like a Z4 would be the minimum.
You can measure it without causing damage. In a clear lot, put a marker on the ground directly below the outside rear corner. Execute your full lock turn slowly and when you gone a few feet stop and place a second marker. Measure the lateral distance between the two. If you have a second person, they could mark the maximum distance without you having th guess at it.
2010 E93 335i M LeMans Blue
2001 E 46 330ci Coupe/silver/black/Sunroof 1999 BMW R1200C Cruiser-Ivory & Blue |
09-16-2010, 08:53 AM | #11 |
Rep 54
Yes, this did happened when I was a kid and saw my dad was driving his 1974 caddilac out from a parking lot. The Caddilac was super close to another car parked next to it, so when my dad turned his steering wheel all the way left and moved foward, the tail just hit slightly to that vehicle. I believed this would only happen to rear-wheel drive automobiles which their front wheels turning angle are big.
09-16-2010, 09:12 AM | #12 |
1646
Rep 4,877
It's goverend by the overhang of the body from the front/rear wheels. Th caddy had a HUGE trunk that stuck out. Typically, same went for the nose.
BMW has hardly any overhang (like most modern vehicles). Putting the wheels further forward/back increases cabin room and vehicle stability. |
09-16-2010, 09:42 AM | #13 |
Supreme Allied Commander
1963
Rep 61,781
Drives: A BBS WHORE
It all depends hot long is your trunk from your rear-wheel (pivot point).
09-16-2010, 02:17 PM | #14 |
26
Rep 213
yes it is definitely possible because when you turn a bit of the back bumper comes out. for example if you turn left your back swings right and if you turn left your bumper swings right. This happens because the end of our car does not end where the top of our rear wheels are. I know this because i ran into a pillar trying to squeeze between a car and a pillar turning. my rear hit the pillar and scraped.
09-16-2010, 04:23 PM | #15 |
Rep 262
Drives: 09 911 C4s
lol I'm not the only one who wonders about this. Put up a bunch of cones, try it and see what happens
09-16-2010, 06:06 PM | #17 |
147
Rep 2,383
IMHO, it's called tail swing.
Speakers: CDT Audio HD-42 comps--front doors (RAAMmat deadened), CDT ES-06 6.5" woofers--kickpanl Pods, Hertz EBX202R dual 8" ported trunk sub. Amps: Phoenix Gold RSd 500.4 (comps & pods). PG RSd 600.1 (sub). Power & Ground: 4AWG Streetwires w/RockFosgt RFDB1 distro blocks. Input: HU lineout--Kicker KISL RCA adapters--RockFosgt RFIT-6 cables--Audiocontrol Matrix--Monster cables--RSd 500.4--lineout Monstr Cabl to RSd 600.1.
09-16-2010, 08:01 PM | #18 | |
Rep 284
