BMW can't figure out the problem with my 335XI, can you??
09-14-2010, 06:09 PM | #1 |
547
Rep 2,590
Purchased a 2009 335i Xdrive about 1 month ago with 6.5k miles on the odometer from a BMW dealership. I purchased the car sight unseen like I have with the past 5 cars my wife and I have purchased. We have only bought from dealerships in the past and have had excellent experiences.
So when I got the car, the engine sounded strong and the car appeared to be taken care of. Car had a clean carfax, there was a small bumper repair but it was all cosmetic. After a day of driving I noticed that speeds of 60 to 80mph the car would vibrate. If felt like an out of balance tire so I went to the dealership after my trip and they balanced the tires but the problem still was there. After swapping out the rims/tires on my car with a set the dealership had laying around, the problem still was there which ruled out the tires. As of now, the dealership has done the following: 1.) Replaced driver side axle 2.) Replaced differential 3.) Replaced Motor Mounts 4.) Replaced rotors 5.) Replaced passenger side axle 6.) Replaced drivers side hub assembly 7.) Tires have been balanced on a hunter roadforce machine 8.) Tires/rims have been swapped to determine if it was a tire/rim issue and the problem was still there. 9.) An alignment was completed. After all of this, the problem still is occurring and they are moving on to the transaxle then to the engine. Symptoms: 1.) Vibrating from 60-80 whether Im accelerating, coasting, or braking 2.) It is felt in the seat, if you put your head on the headrest, it feels like a harsh massage. 3.) The car accelerates/cruises smoothly from 0-60, no clunks, no thumps, no shuddering or vibrating. 4.) Brakes are smooth, no vibrating during braking. 5.) Car gets good gas mileage 6.) Makes no whistling or grinding sound indicating a wheel bearing. 7.) Car throws no codes So please help if you have any suggestions. Last edited by pits200; 09-14-2010 at 07:44 PM.. |
09-14-2010, 07:06 PM | #2 |
Corporate Hack
Rep 288
Wheel bearings perhaps? Worn wheel bearings can cause vibrations while driving. The fact that its at a particular speed though makes me think that its a wheel out of balance. Have you tried getting the wheels balanced by someone other than the dealer? They might just suck at balancing...
New Car: 2008 335xi Coupe
Earlier Car: 2004 STi (got stolen) Earlier Earlier Car: 1995 Mustang GT (416 whp and a blown engine) Really Much Earlier Car: 1988 Mazda 626 TURBO |
09-14-2010, 07:23 PM | #3 |
547
Rep 2,590
They have a hunter roadforce machine there which is pretty much idiot proof and very accurate.
In addition, they actually removed my tires/rims and replaced them with a brand new set of balanced rims and the exact same problem was still there. As for the wheel bearings, the car only has like 7k on the odometer now.. Ah gees, least its all covered under warranty. |
09-14-2010, 07:31 PM | #5 |
1911
Rep 13,104
Have some body drive in another car
Have somebody drive another car beside you and see if anything can be seen
visually . Mount camera to the underside pointed at the suspected parts. |
09-14-2010, 07:34 PM | #6 |
Rep 182
Drives: 2006 330i
335?.....HPFP.
09-14-2010, 07:35 PM | #7 |
253
Rep 7,089
Drives: '06 AW 330xi
Bushings? Although with your low mileage, your bushings should be fine....for at least another 40K. However even with a car fax you don't know if the previous owner had done any suspension mods that could have accelerated wear on your bushings.
Sounds like you haven't tried an alignment? |
09-14-2010, 07:37 PM | #8 |
253
Rep 7,089
09-14-2010, 07:37 PM | #9 |
39
Rep 1,558
Sounds like the front driveshaft (from transfer case to front diff) is out of balance. Tell them to replace it and I bet your problem is gone. Or even the rear driveshaft for that matter. Or both.
Sport pack, JB3, Dci, factory oil cooler, 18" M3 reps, Michelin PSS, painted trim, black grills, smoked side markers, LED plate lights, H&R coils, Borla catback |
09-14-2010, 07:43 PM | #10 |
Rep 182
Drives: 2006 330i
It was a joke.....way to see pass the sarcasm.
Quicker answer, NO. |
09-14-2010, 07:44 PM | #11 |
547
Rep 2,590
Whoops, forgot to mention.
Yes an alignment was done, I'll edit the original post. Thanks for all the input so far. As for mods being done to the car prior. It was a demo car that the gm of the BMW dealership drove. So I can say with strong confidence that the car most likely wasn't modded. |
09-14-2010, 07:48 PM | #12 | |
253
Rep 7,089
Doesn't matter if God drove it....there was a post a while back on the M5 board that described a situation where a BMW employee totaled a customers car. And the dealer tried to cover it up and make the customer pay $1500, IIRC. Which "coincidentally" was the insurance deductible for the dealer. |
09-14-2010, 07:54 PM | #13 |
Rep 182
Drives: 2006 330i
It's cool *********.
Once again all is right in the world. |
09-14-2010, 07:58 PM | #14 |
547
Rep 2,590
Im agreeing with JO2 that its one of the drive shafts. They are going to call and give me updates every 2 or 3 days. The car has been worked on for the past 3 weeks and they are still baffled.
09-14-2010, 08:06 PM | #15 |
21
Rep 147
Chief,
"It is felt in the seat, if you put your head on the headrest, it feels like a harsh massage." Did you check that your seat is bolted down correctly? Won't hurt |
09-14-2010, 08:09 PM | #16 | |
547
Rep 2,590
But the vibration kind of goes away over 80mph, if it was just the seat, id assume it would be there at all speeds. The problem is also felt in the steerin wheel but not horribly. |
09-14-2010, 08:20 PM | #17 |
21
Rep 147
Not necessarily. Every mass/force system tends to have a natural frequency at which it is excited to resonance. In your case, the resonance might occur at 60-80 mph. If one or all the screws holding the seat are not tight enough, you might experience the resonnant vibration. Just my nerdy 2 cents
The steering wheel vibration, though, doesn't fit my analysis Good luck. |
09-14-2010, 09:13 PM | #18 |
Rep 291
Drives: 2008 328i, with 3 pedals
Hi,
I had a car once that exhibited similar behavior. I finally took it to a specialist suspension shop in my area (Custom Alignment, Mountain View, CA) and after a little study, they figured that the wheels needed to be balanced on the car. Regular balancing on a machine with the wheel off the car didn't pick it up. Not sure how they do on-car balancing but it completely cured the problem. Any rotating mass can contribute so the idea that has been floated of bad axles may be part of the problem. Please let us know what you find. Regards, Adnan |
09-15-2010, 09:33 AM | #19 | |
34
Rep 616
I had a similar problem on my '67 Bronco ( i know, completely different vehicles). The problem only occured over 60 mph when cruising or if I let off the gas. I replaced the 43 year old driveshaft with a new, balanced one and now it's super smooth on the highway. I also had really bad wobbling over 40 mph before that which was fixed with new tires (old ones had flat spots) and new front end bushings. That was a different type of feeling though. The problem you're describing and speed at which it happens definitely sounds like a driveshaft issue. |
09-15-2010, 09:40 AM | #20 |
922
Rep 5,538
Vibrations are hard to troubleshot.....Maybe the accident was bigger then you think, something moves 1mm and there you go.....I traded-in my Audi, started to have weird vibrations after a not so big accident....
glad to hear they are replacing stuff for you...... |
09-15-2010, 10:29 AM | #21 |
34
Rep 221
I was going to post the driveshaft as a possibility but someone beat me to it.
I would also check the rear axle, not just the front. I was also thinking bad gear in your differential but I see that was replaced. The parts that have been replaced, as well as the symptoms, point towards being drive shaft related, IMHO. |
