opinions on KW V1's on boston roads?
09-14-2010, 07:50 AM | #1 |
19
Rep 190
Hey all, I've been considering the KW V1's ever since I got my 335xi...but after fixing 2 bent rims and 1 blown tire, I'm now extremely weary...
I dodge potholes like BULLETS but sometimes i still get sniped by those sneaky holes once every blue moon... So any objective opinions on whether or not the V1's will be a worthwhile investment for downtown boston roads? I live in Watertown, but work and often go downtown. Also, I'm still on stock 18" rims with Continental DWS. Any input would be great |
09-14-2010, 08:02 AM | #2 |
123
Rep 4,249
I'm guessing they're not much better than the stock set up from a pot-hole perspective, but I don't know for sure as I've never experienced them. I'm running KW Street Comforts at a very soft setting and I still feel the need to dodge potholes as well, but the ride is fairly significantly improved over the stock suspension. I'm assuming the street comforts are quite a bit softer than the V1s and I don't believe the V1s give you damping adjustments which is why I'm guessing they won't do much better than stock from a pot hole perspective. In fact, I'm guessing they'll be even stiffer and make it worse for you and this is the main reason I went with the street comforts.
09-14-2010, 09:13 PM | #3 |
***** noob
1369
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
i heard good things and bad things on the V1s
checkout the XI section....alot of ppl with the V1s
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
09-14-2010, 10:06 PM | #4 | |
19
Rep 190
09-28-2010, 09:11 PM | #6 |
306
Rep 7,433
I would personally go with the Dinan set-up...very conservative yet noticeable drop that will def improve handling but won't sacrifice ride quality too much
