335is stick shift
09-13-2010, 04:52 PM | #1 |
1067
Rep 1,946
335is stick shift
So those who own a 335is stick, is it a nice engagement and clutch to live with on a daily basis?
I am coming from a porsche that had a bulky, noisy standard transmisson and the clutch was really stiff... just wanted to see what the community thinks about the 6 speed set up. since i bet the dct is butter! |
09-13-2010, 05:27 PM | #2 | |
AC
95
Rep 2,387
you will get bored with DCT very soon, but coming from a purist, this is the type of answer you should expect.
Your Supreme Leader
09-13-2010, 06:03 PM | #3 | |
483
Rep 10,309
Drives: A///MERICAN!!!
OP - find one to test drive. FWIW the 6speed manual is the same as in the regular 335. I drove both before going with an auto, the only problem I had with the 6sp was the notchy 1-2 shift but other than that it was a blast to drive. For what I use my car for, however, I am happy with auto. What I mean is I didn't not buy a manual because I didn't like the transmission, it was because for my DD I didn't really feel like having a manual anymore. Last edited by BTM; 09-13-2010 at 06:10 PM.. |
09-13-2010, 06:11 PM | #4 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
Brian,
The notchiness that you talk about is due to the clutch delay valve. Remove that and then add a clutch pedal bump stop to eliminate the extra pedal travel. You'll end up with butter smooth shifts every time. For as long as I have both of my legs and my knees are working fine, I will NEVER drive a DCT/AUTO/SMG/Flappy Paddle gearbox.
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
09-13-2010, 06:14 PM | #5 | |
483
Rep 10,309
09-13-2010, 08:13 PM | #6 | |
Rep 284
09-13-2010, 09:05 PM | #8 |
343
Rep 1,465
i had considered the 335i auto before buying the stick, even though in my mind i wanted the stick.
I went to five dealerships across southern california to test drive the 335i all auto before my purchase. Why did I went to 5 dealerships? because many of them won't let you drive it again and again. Anyhow, the regular auto in the 335i i found was a bit sluggish in throttle response. once I test drove a used 335i 6mt on the lot, I was sold. Immediately, I ordered the car in stick. the clutch in the 335i is one of the smoothest as well as soft-linear pedal feel ever. Compared to my girlfriend's 350z, it is a lot better in traffic. The 350z stock clutch was brutal in stop and go !! yet, it's engagement and grip was not significantly better than the 335i. however, if you're in downtown LA, any stick car will be hell as it gets tedious. But because i commute to irvine everyday, where the speed limit is 50-55mph on surface streets, there's not a corner where I don't punch that sucker to 60mph. the only con of the 335i 6mt is in extremely fast speed shifts, you will feel the clutch delay valve hindering the engagement. Also, I upgraded to the BMW performance short shifter, much better, as the stock throw was a bit long for me. |
09-14-2010, 06:04 AM | #9 | |
Rep 123
Drives: 2011 335xi Coupe
Garage List 2011 335xi Coupe [0.00]
2001 Porsche 911 Turbo [0.00] 1967 Camaro RS/SS 3 ... [0.00] 2010 Hyundai Tucson [0.00] 2010 Accord Coupe 4 ... [0.00] 2009 Accord Coupe V ... [0.00] |
The BMW shifter is smoother and requires less force. Clutch effort on the Porsche is higher, but still very light IMO. Both clutches have this amazing 1 inch or so engagement travel range that, once you know where it is, you can shift flawlessly. Both transmissions feel equally precise in gear shifting up or down. Now one BIG difference non-transmission - goto WOT and the Porsche is in another world of acceleration.
Rick
09-14-2010, 12:51 PM | #10 | |
AC
95
Rep 2,387
nobody in this forum will be answer to OP's question if all of us need to know him in person (except for the ones that actually know him).
my advise is based on all the debates I have seem on this forum on the topic of "stick vs. auto". this is an extremely touchy subject and I understand my opinion will offend a lot of people in this forum. btw, test driving is not the same as driving something day-to-day, I have seen a lot of people regretting they got the AT instead of the MT because they had a "great" test drive on the AT. On the contrarily, I have yet to see a person on this forum regretting getting the MT. Quote:
Your Supreme Leader
09-14-2010, 03:06 PM | #11 | |
1121
Rep 5,396
However, after this initial experience was over, I found the DTC boring and less engaging than the manual transmission. Not to mention the obvious lack of clutch control you get from the manual tranny.
09-14-2010, 03:08 PM | #12 |
483
Rep 10,309
Vasil - DCT is not the same as DSG...DSG is much more crude (according to most reviews with the dual clutch transmissions)
09-14-2010, 03:13 PM | #13 | |
483
Rep 10,309
Here is a recent example of someone who has DCT in their is and loves it http://www.e90post.com/forums/showth...&highlight=DCT |
09-14-2010, 03:33 PM | #15 |
483
Rep 10,309
09-14-2010, 03:40 PM | #16 |
World's Foremost Authority
1181
Rep 4,535
Drives: M4 Cab - Cayenne GTS - Jag XK
Location: Upper East Side Manhattan - Boca Raton FL - Lime Rock CT
You can't really go wrong with either and it is a matter of personal preference. The DCT is a form of an automatic tranmission. It is a suberb automatic transmission and in manual mode the driver has complete control over gear selections. Although the technology of the Steptronic is very different than the DCT the driver experience of a DCT is closer to a Steptronic than a manual transmission. In many ways the DCT is better at being an AT than a traditional AT. It does not have the jerkiness of the earlier SMG. The shifts are smooth and instantaneous.
You will have to drive them both yourself and come to your own conclusions. I happen to enjoy driving a variety of cars and whether it is a DCT, a Steperonic type automatic or an MT is not my top priority. CA
Drivers Club at Lime Rock - International Motorsports Research Center - Society of Automotive Historians - Madison Avenue Sports Car Driving and Chowder Society (0nly a VP) - BMWCCA - Porsche Club of America - M Gruppe - Polish Race Drivers of America (PDRA) - Glen Club (Watkins Glen International) - Jaguar Club of Southern New England |
09-14-2010, 03:47 PM | #17 | |
483
Rep 10,309
DCT /= Steptronic. The bottom line is all three are great choices, just choose the one that works best for you. Why other people get so defensive about people who choose something else over MT is beyond me...only when someone else starts paying for my car can they insist what transmission it should have |
09-14-2010, 03:48 PM | #18 | |
119
Rep 2,312
Does 911 carrera have a clutch delay valve? |
09-14-2010, 03:51 PM | #19 |
Cars & Guitars
Rep 97
Regarding the OP's question about the manual tranny in the 335is, I read in Roundel that it comes stock with the short shift kit. Does anyone know if it's the same SSK that BMW sells as an aftermarket option for 6MT 3'ers (see link below)?
For those that have driven both the 335is 6MT and a regular 335i 6MT, are the 1st to 2nd shifts any smoother, or does the SSK actually compound the sometimes notchy shifts? http://www.bmwusa.com/Standard/Conte...ShiftKits.aspx Thanks.
2008 E90 335i >Blue Monaco, Lemon/Aluminum, 6MT, Sport, Prem, Cold, iPod, CA, Sirius >European Delivery in April 2008
09-14-2010, 03:53 PM | #20 | |
483
Rep 10,309
FWIW I'm always seeing positive reviews of the SSK, and many in the "what's your favorite mod" thread rate it as their favorite - so it must be doing something right |
09-14-2010, 05:00 PM | #21 |
AC
95
Rep 2,387
BTM is correct, call us when you hit your 2nd anniversary with your car.
By that time, there will be three (3) likely outcomes: 1. You still love your DCT and will keep the car until the lease ends or drives it until it grinds to the ground (if you bought it). 2. You will hate you DCT and can't wait until the lease ends. 3. You will think of getting a new car (because you are bored with you DCT). Outcome #3 will be most likely, but, anything is possible...
Your Supreme Leader
09-14-2010, 05:13 PM | #22 |
Philosopher-king
20
Rep 1,113
I actually learned to shift gears on a 911S with the legendary 901 transmission and cable-actuated clutch!
Two "classic" SAABs followed. Compared to those, the BMW clutch/transmission is utter perfection and an absolute delight to shift.
E91 6MT Alpine, Terra, Xenons, ZSP, ZCW, ZPP, PDC, CA, alarm, M shifter and M brake handle, Euro rear fog light switch, Euro aspheric mirrors, rear power outlets, Garmin nüvi custom cupholder mount, Lidatek, V-1 built-in remote display, tire pump, jack, floor mats.
