break in question
09-13-2010, 12:31 PM | #1 |
Rep 8
break in question
Hello, I just got my new 330i the dealer told me that I do not have to break in the engine, so I took the words for granted and I floored it on my second day :S and I kept doing so ... now I read somewere here on the forum that it is mandatory to break in ... am I screwed ?? :S:S:S
09-13-2010, 12:35 PM | #2 |
15
Rep 410
There are different schools of thought when it comes to this--some recommend to flog it some just say drive it like a baby. I would say the worst things you could do during break in are driving at load and revs before the engine is warmed up, constantly driving short distances, driving at high load in a high gear. Avoid those things and just drive normally and you should be fine.
09-13-2010, 01:42 PM | #4 |
28
Rep 268
Some say flogging it will make the engine stronger due to the pistons sealing better. However a break in that went easy and with the car being babied means the other components, like the drivetrain, wont be stressed prior to proper seating.
09-13-2010, 02:53 PM | #5 |
[]D []-[] []_[] []< []\[] []_[] ']['
27
Rep 418
Drives: 335i Convertible/Le Mans Blue/
Unless the "some say" crowd has done controlled testing to include tear-down inspections of components, I would go with what the manufacturer recommends.
2010 E93 335i M LeMans Blue
2001 E 46 330ci Coupe/silver/black/Sunroof 1999 BMW R1200C Cruiser-Ivory & Blue |
09-14-2010, 05:05 AM | #6 |
Rep 8
well I do let it worm up and I continue driving it like a baby for the first 15 mins but then I start flooring it from time to time, I do not keep flooring it for a long time, I just accelerate to a certain speed and then I cool down I do not carry heavy weights while doing so, just me in the car, and I don't floor it on up hills. the reason why I thought it shouldn't be driven like a baby is that oil change is required on 12000 km, I thought only cars that should undergo careful break in are those which require oil change in 1000 km.
09-14-2010, 05:43 AM | #7 | |
103
Rep 2,783
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
09-14-2010, 07:31 AM | #8 |
Driver
37
Rep 1,577
09-14-2010, 07:36 AM | #9 |
vrooommm
11
Rep 145
Drives: 2008 BMW E92 335i
Over there, yes, over here (europe) the 330i is still very much available...
BMW E92 - 335i - Spacegrau - Black Dakota - AT - BMW Performance style 313s (19) - BMW Performance suspension - M-aerodynamics - BMW Performance diffuser - considering: BMW Performance exhaust
09-14-2010, 09:01 AM | #12 |
20
Rep 201
I've read the manual. I know the part where it mentions not warming up. However, that probably doesn't mean you should beat on the engine while it is cold, either. I'm sure BMW meant that somewhere between Grandma and NASCAR is appropriate.
09-14-2010, 12:08 PM | #13 | |
AC
95
Rep 2,387
1200km, that's the break-in period for engine, clutch, and brake pads.
500km for tires. Except for tires (where you can flat spot them), if you can only doing it once or twice, it will be fine. The more important part is not to overload your car (with too many people or "stuff") before 1200km. Quote:
Your Supreme Leader
09-14-2010, 01:20 PM | #14 | |
124
Rep 5,627
Tom |
