BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > good/bad? Swapping front springs and not back
      09-09-2010, 01:18 AM   #1
xxp0loxx
xxp0loxx's Avatar
18
Drives: e92 Space Gray ACS
I'm currently running 20's, have about 2" clearance in front and 1'' in back (rear fenders rolled). Front is 245/30/20 and the rears are 285/25/20. I'm a suspension novice. I'm looking to lower the front by around an inch to close the gap a bit and match the clearance in back. Would only swapping the front springs to an Eibach set be bad on the all stock suspension? and is an alignment the only thing required after doing so?
thanks in advance
      09-09-2010, 08:09 AM   #2
MassBimmer
MassBimmer's Avatar
No_Country
306
Drives: 2023 i4 M50
2009 BMW  [9.24]
Check out the lowering spring perches from Supreme Power, should be what you're looking for
      09-09-2010, 10:02 AM   #3
xxp0loxx
xxp0loxx's Avatar
18
thanks, ill check it out.
      09-09-2010, 01:47 PM   #4
Wlew
Wlew's Avatar
77
Drives: 2011 E90 335i
I think it would make the car handle oddly. I would not recommend doing so. Eibach pros only drop about .6" over sports suspension anyways. I would not do it, but thats just me.
keep us poted.
2011 335i Sports Package | VRSF FMIC | Cobb AP3 | Dinan Exhaust | BMS Intake | VRSF CP | Lux H8 Angel Eyes | Mtec LED Fogs |
      09-10-2010, 03:05 AM   #5
xxp0loxx
xxp0loxx's Avatar
18
ok, like i said, im a suspension noobie. so when a kit says a drop of 1" F, 1.5" R i need to deduct the stock drop of .6" from each to get the new ride height? makes sense to me but just making sure.
I.E. the new ride heights will be .4" lower in front and .9" lower in back compared to the stock ride height.
