H&R Sport Springs Questions
09-09-2010, 12:19 AM | #1 |
173
Rep 688
1) The springs have been used for 2000 miles. How long should I wait to get an alignment performed since the springs have already settled once before?
2) I understand the ZSP sport suspension on the E90's receive less of a drop compared to the standard suspension. How much of a drop should I expect? 3) Will Continental DWS tires fit with a 18mm spacer in the rear (255/35/18) and 10mm in the front (225/40/18) with minor to zero issues? Thanks in advance! Greg
06 E90 330i 6MT Sport Prem Cold
09-09-2010, 07:23 AM | #2 |
Rep 183
1). Couldnt tell ya
2) I believe it's. About .6 .8 inches since it's. 1.3 1.4 with the non sport suspension. 3) I have an 06 as well and i am using 225/40/18 s'in the rear with a 25mm spacers and it fits just fine. Using 6mm in the front. Only problem i had is that my rear actually dropped a lot more than the front and i have no idea why but it doesn't look all that good, i m thinking i should buy the blistein shocks now... |
09-09-2010, 08:07 AM | #3 | |
306
Rep 7,433
2.) about another 3/4's of an inch 3.) Are they stock wheels? If so, a 15-18mm spacer in the rear should be good. 10 mm in front may be a bit too much Bilstein shocks/struts won't help you. There is naturally more rake in the xi's and the H&R sports are an even drop all around, unlike the Eibach's, which lower 1" in front and .75" in the rear. To remove the rake, you may want to consider getting front lowering spring perches from Supreme Power. It will lower the front an extra .25 - .50 inch to remove the rake |
09-11-2010, 01:34 PM | #4 | ||
173
Rep 688
From your experience with the DWS, do they have a smaller sidewall/rounder sidewall compared to Bridgestone tires? (specifically the RFT or RE760 sports)
