Break in oil
09-11-2005, 02:31 AM | #1 |
Rep 91
Break in oil
It is my understanding that synthetic oil is insuffecient (too slick) to proberly seal the rings for break in. I will acquire my 330i at the end of the month, and intend to immediately replace the synthetic oil with dino oil to facilitate proper break in. To me, this seems like a no-brainer, and I am surprised that this has not been brought up before. Am I missing something? Please advise.
E90 330i Ti Grey Burl/ZSP/ZPP/Navi/PDC Manual
09-11-2005, 02:33 AM | #2 |
33
Rep 1,770
Actually, this has been discussed a lot here recently. I just passed the break in period last week (currently 1360 miles) and I don't plan to change it until my next service
And I'd rather not do the first oil change myself. I worry that I might mess something up. How much does the dealer charges for a wanted oil change?
2006 330i Steptronic/Alpine White/Black Leather/Burl Walnut Trim/Premium Package/iDrive/Heated Seats/Winter: STYLE 159 Blizzak LM-22 RFT/Summer: TBD
2004 X5 Steptronic/Alpine White/Grey Leather/Poplar Trim/Premium Package/Heated Seats/iPod Adapter |
09-11-2005, 02:34 AM | #3 | |
MAUI BUILT
485
Rep 7,781
Drives: 2006 330i MT
Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
09-11-2005, 02:43 AM | #4 |
Rep 91
Hi OZ, thanks for the reply. I don't believe that the issue of whether or not synthetic oil is suffecient for break in as opposed to dino oil has ever been discussed here. There has been plenty of discussion regarding when to change the synthetic oil though. To me that is clear... 1200 miles to flush out shavings etc.. My question concerns the initial (and all important) <50 miles when the piston rings seal. It has always been my understanding that dino oil is superior to synthetic in that regard when it comes to sealing the rings. I would appreciate any thoughts on dino v. synthetic during the short but vital break in period.
09-11-2005, 02:54 AM | #5 |
Rep 91
HRC - thank you for your reply. I appreciate your comments, but to say that BMW has designed the engine to run on synthetic oil without data as to how, concerns me. The rings still need to seal. The slippery nature of synthetic still concerns me. Unless they figured out a way for the rings to seal adequately with syn as opposed to dino then I am still concerned. Dino oil is superior to synthetic for break in. Am I mistakin'?
09-11-2005, 04:08 AM | #6 |
1311
Rep 10,185
The tolerances to which these engines are built means they dont need break-in oil.
We tested a E46 at a tuner before work was carried out on it. The car had normal BMW paid services at the stipulated intervals and had over 100,000Km on it, and we tested the compression in each cylinder. The compression was perfectly within factory spec for each cylinder So the rings were perfectly seated with the normal oil. With the older engine building technology and tolerances one had to run mineral oil because it took quite a while for the rings to seat, but has not been the case for BMW engines for quite a while now |
09-11-2005, 04:10 AM | #7 | |
101
Rep 3,566
Drives: F30 M-Sport 328i Estoril Blue
I have owned BMWs from new since 1992 without any break in or further problems using BMW's oil. This issue you have just brought up interests me if what you understand from Dino oil holds true. Are there conclusive tests carried out on cars to show that Dino oil is better? What about long term use of Dino oil? I await further information with much anticipation. Thanks very much.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
09-17-2005, 08:52 PM | #8 |
Rep 51
Drives: E90 325i
What engine oil do you use? My friend recommended Torco racing oil(SAE 10w-30), anyone using?
I'm planning to change my engine oil after the break in period, can someone recommend the right engine oil besides Castrol which BMW recommends. |
09-25-2005, 06:29 PM | #10 |
Rep 51
Drives: E90 325i
That's was what my friend used on his E46 and claims very smooth. Not sure if Torco Racing oil comes in 0w-40.
But most lightly, I will stick to Mobil 1 since is LL01 or/and recommended by most BMW mechanic, especially for me since I'm not using my E90 for track or race. |
