Seafoam 335d?
08-13-2010, 01:26 AM | #1 |
17
Rep 70
Seafoam 335d?
Has anyone seafoamed the 335d to help with the issue of carbon build up that is plaguing all DI cars?
I wanna know how to do it on the 335d before the issue of carbon build up arises, so it'll be a bi-annually thing. |
09-03-2010, 04:23 AM | #3 |
198
Rep 4,647
there are several people on e90 did seafoam on N54 but i'm not sure about diesel platform... i woul think it'd be pretty much same though...
SGE92TT......................... 12.331 Sec @ 117.89 Mph............................POWERED BY
l BMS DCI l HELIX IC l FORGE DVs l RR OCC & CP & SCOOPS l AR 3" DPs l AE QUADs l BLISTEIN PSS10 l P3 VENT GUAGE l VISHNU PROCEDE V5 AUTOTUNE l Lots of Window Stickers |
09-03-2010, 05:16 AM | #4 |
164
Rep 2,409
09-03-2010, 04:02 PM | #6 |
king of the hills
92
Rep 2,915
Drives: 2011 M3 w/ESS55, 2001 540i/6
NO! Do not add Seafoam (or any top engine cleaner) to the intake manifold of a diesel engine as there is a good likelihood of hydro-locking the engine. Compression in Diesels is very high, and there is very little tolerance for adding a non-metered liquid in there along with the air.
You can add to the crankcase or fuel tank safely, but that will not clean the intake valves obviously. |
09-03-2010, 04:11 PM | #7 | |||
486
Rep 1,614
From the Seafoam Sales website: Quote:
09-03-2010, 04:16 PM | #8 |
king of the hills
92
Rep 2,915
Just another point, if you are getting serious coking on the valves, don't forget to check the EGR and PCV/breather, as these are usually the first things to get clogged up on a diesel. Most likely to clean the valves properly on a diesel, you will need to remove the intake manifold and clean them individually, this is really the only safe way.
Typically, diesels have very little room between TDC of the piston and the valves, so anything in the cylinder that isn't metered can easily cause damage. |
09-03-2010, 09:58 PM | #9 |
198
Rep 4,647
so it's ok on 335i but no good for 335d
09-03-2010, 10:00 PM | #10 |
Speed Demon
205
Rep 3,690
Not in the same fashion that you'd do it on an i, that's correct.
Current: '21 M5C, '15 X6 50i Previous: '18 M550i, '16 550i, '11 335is, '09 E93 M3 DCT, '10 E90 335d, '07 E90 328i |
