08-04-2010, 09:12 AM | #1 |
Rep 35
Seeking Some Advice
Hey guys, I'm 17, 6'4", and 170lbs (roughly). For the past 3 years I've worked out during the school year while taking whey protein (the crappy GMC generic brand because I was uninformed at the time). I had gotten my weight to around 187 when I went through a bout with cancer and I dropped down to 160 because I was unable to workout for 3 months after the surgeries. Over the past 6 months I've gotten my weight back up (to 170) but I'm still way below where I want to be.
Okay, so on to the questions. I will have up to 2 hours a day, 5 days a week to workout in a college weightroom (think LA fitness level and quality). I would like to gain quite a bit of lean body mass. Basically, I'd like to go from 170 to between 185 and 190. What workout routines would you recommend? What supplements (both pre and post workout) would you recommend? What nutrition staples do you think I should be focusing on? Any special notes, things to watch out for, further advice, etc.? Thanks |
08-04-2010, 09:32 AM | #3 |
Rep 35
At the moment I'm actually a senior in high school doing a dual enrollment program so it's actually a community college (with a brand new weight room) but come next summer I'll be at UGA.
08-04-2010, 04:12 PM | #4 |
37
Rep 608
There will be different opinions and different ways of going about this, but basically it's about eating a clean diet and consuming more calories than you would normally. Do cardio, but not excessive amounts. Plyometrics, circuit, anaerobic, general weight lifting, and lots of core. You need a lot of rest, protein, and hard work. Don't let your body get used to the same lifts and routine, make it difficult every day. You might even want to incorporate flexibility.
08-28-2010, 12:00 AM | #5 |
Rep 57
Workouts are workouts, find somethings you like and perfect them, it doesnt take anything special to reach your goals. Gaining weight means taking in more calories, however try to eat lean( other than genetics, the way you eat will decide the way you look). I only take GNC unflavored protein powder, i just dont belive in all the those other supplements. All natural as much as possible is the only one to go in my book. I can back up everything ive said with the results ive had with my body, and those ive had the pleasure of working with.
09-01-2010, 10:35 PM | #6 |
41
Rep 1,223
i would recommend 16 calories per pound, but for you maybe even 20 calories bc you're only 17years of age and your body metabolism should be high. Your protein should be from food consist of chicken breast, lean beef, etc. And your carbs should be from whole wheat, brown rice, yam, potatoes etc. Basically all your healthy stuff. PPL dont eat enough nuts! Its good for you.
I would recommend you do alot of body weight workout i.e. dips, deadlifts, pullups...im working out for years and realize the most important thing is your core muscle. U clean that up and you'll see results like you wont believe. check out these sites for more info www.crossfit.com www.bodybuilding.com Good luck and most important have fun working out! It shouldnt be a chore. |
09-02-2010, 07:57 AM | #7 | |
224
Rep 2,548
If you want to get big, many people use the 5x5 system. |
09-02-2010, 11:09 AM | #8 |
18
Rep 439
First of all, im glad you are doing fine now!!!
Read here http://www.body-building-resource.com/bb90.shtml what to eat
L.E.T.S. G.O. H.A.W.K.S.
09-02-2010, 01:08 PM | #9 |
39
Rep 346
Drives: 2007 Corvette Z06
Congrats on the recovery!
As for your questions: - What workout routines would you recommend? Rippetoe's Starting Strength - What supplements (both pre and post workout) would you recommend? Protein, but really you just gotta eat, and eat lots. - What nutrition staples do you think I should be focusing on? Eat eat eat Any special notes, things to watch out for, further advice, etc.? Eat + Rest, make sure you get enough of both and train hard. http://startingstrength.com/ http://startingstrength.wikia.com/wi..._Strength_Wiki
"Its only after we’ve lost everything that we’re free to do anything"
Current: 2007 Corvette Z06 (DD/HPDE) Past: 2012 MazdaSpeed 3, 2007 BMW 335i E92 - 2001 Corvette Z06 - 2001 Camaro SS - 2007 CBR 600RR - 2003 CBR 600RR Racebike - 2001 CBR F4i |
09-02-2010, 06:28 PM | #10 |
322
Rep 17,316
Drives: E92 M3, E30 325i
i remember reading in a few different magazines a while back that you should consume 1 gram of protein for every pound you weigh to add size?
09-03-2010, 12:17 AM | #11 |
Rep 13
X5 E53 3.0D
Hi mates, does anyone know how to actiate the cold box under the driver middle armrest? is there a button to control or even switch on, as the cold box had a vent but no air coming out... thanks
09-03-2010, 12:09 PM | #12 | |
1042
Rep 5,660
To it, however, I'd add that you should focus less on any particular weight number and focus more on (1) how you feel (strong, energetic, flexible), (2) your ability to do the physical things you need to do (assuming your interest is to enable something in particular), and (3) how you look, that is, do you look fit and sexy. I say this because it sounds, based on what you describe as your pre-op height/weight, you may naturally have an ectomorphic body type, and if that's the case, putting on size/weight specifically will be considerably more challenging than for either of the other two general body types. On the other hand, if over time your endurance and strength are increasing and you feel good and the folks you want to "get freaky wit' " are showing you enough attention, you should not worry about being over/under any specific weight. Though I'm not quite as tall as you, I am of the ectomorphic type. My lifting routine (I do it 5 days a week with a trainer) is the "body parts" approach, which basically amounts to intensively working out one or two body parts + core each day for about an hour (give or take). Seven days a week, I run/jog 3 miles, and on two of those days I run/jog 6 miles. Diet certainly plays a large role. My regular diet consists of pretty much the same thing every day, except for the two monthly "excesses" I allow myself. Daily morning pre-workout meal (45-60 minutes prior to working out): Oatmeal, dried fruit (2-4 oz of any one of the following: cherries, raisins, blueberries, currants), brown sugar. On "leg day," I will also have 4 oz of microwaved salmon. (Season with S&P and fresh lemon slice/juice and microwave at 50% power for 2 -3 minutes (longer if the portion is larger. The best time varies by microwave, but once you find the right duration, you'll be amazed. This technique works for any fresh fish, but is best with salmon, halibut, haddock, catfish and swordfish.) Watered down protein shake to drink. I water it down mainly to make it more watery and thus more drinkable than "eatable," as would be so for a thick shake. Protein shake - I prefer MetRx Double Chocolate. Sometimes I use 1/2 water and 1/2 Chocolate Silk soy milk to make it, and this is most often what I do on the two heavy aerobics days. Daily post workout food and meal: Immediately at the end -- even before showering -- of every workout, I eat a piece of fruit. After I've showered, I do one of the following:
Daily snacks (every couple of hours or so) - no more than 4-6 oz per snack: There's some variety here, but the thing I focus on most is having a small amount to eat every few hours. Partly because I'm always hungry and partly because I don't want my body to think there's a famine and start storing the calories I'm giving it as fat. There are many choices in this area, and as long as the portion size is kept small and the food itself clean and healthy, it doesn't much matter what I choose.
2nd Large meal of the day: Usually I just eat microwaved fish or chicken breast, mainly because it allows me to have gourmet style meals that don't need lots of preparation and I don't like washing dishes and cleaning up the in the kitchen. Occasionally I'll microwave shrimp, but that takes some skills (more than I feel like explaining here) and generally calls for using some butter or olive oil. I rarely eat beef or pork. Not because I can't/shouldn't, but because I like my food to taste really, really good. So I don't often cook beef or pork because:
After the large meal, I just continue the snacks until I go to sleep. Things I never eat:
Cheers,
Tony ------------------------------------------------------------------------------------------ '07, e92 335i, Sparkling Graphite, Coral Leather, Aluminum, 6-speed Last edited by tony20009; 09-03-2010 at 03:50 PM.. |
09-03-2010, 03:34 PM | #13 |
181
Rep 962
