What is a vanos??
08-02-2010, 10:55 AM | #1 |
177
Rep 751
What is a vanos??
Afternoon!!
Can anyone tell me what the vanos does on a 335i? How can you tell if your vanos is faulty? Will it always throw a code if its kaput?? Cheers |
08-02-2010, 11:10 AM | #2 |
Rep 579
08-02-2010, 01:15 PM | #4 |
177
Rep 751
I'm confused, I thought the vanos was a sensor or solanoid?? So the vanos is a mechanincal part of the engine??
Not what I thought it was, if it's faulty would it through a code?? |
08-02-2010, 02:02 PM | #5 |
smokin' kipper
39
Rep 1,467
Current Audi RS5. Previously enjoyed E92 335i M Sport; E92 M3; E92 335i M Sport; E46 330ci M Sport
08-02-2010, 02:20 PM | #6 |
Rep 473
08-25-2010, 09:42 AM | #9 |
Squadron Leader (Ret'd)
25
Rep 627
From what I can understand, it's the BMW name for 'Variable Valve Timing' first found in Hondas. Basically, when the engine hits about 4000 RPM the 'Vanos' alters the timing to optomize the power. On our 130i you can actually feel it kick in as the revs pass 4000.
08-25-2010, 09:47 AM | #10 |
LSD - No, you're not seeing things
72
Rep 3,302
Its similar in principle to the rather more basic VTEC that Honda still employ.
In the Honda, an oil operated valve shunts locks the valve train onto a high lift camshaft lobe - this third (high cam) lobe is not used below 5.5k rpm, the 'tappets' are running on the smaller cam lobes. Its easier if you look at at than to try and describe it! But basically it allows the equivalent of a high lift/long duration camshaft at high RPM (more performance) combined with smooth running and efficient idle at low rpm all in one package. Anyone whos driven a race engine with high lift/long duration fixed timing cams will remember how lumpy and rough they are below say 3k rpm. Found a good vid to explain the Honda version: Last edited by m1bjr; 08-25-2010 at 09:54 AM.. |
08-25-2010, 01:25 PM | #13 | |
14
Rep 454
2A80 Inlet-Vanos variable cam control test, input signal 2A85 Outlet-VANOS variable cam control test Both require dealer visits |
05-03-2015, 11:01 PM | #14 | |
110
Rep 1,340
05-09-2015, 03:11 PM | #15 |
Rep 27
I've just had both replaced... £350 including labour and had my oil changed.
I was quoted £1600... as previous mechanic put it as timing chain issue. I had 6 error codes from oil pressure, vanos, cam chain, timing, crankshaft etc. My car kept going into Limp Mode, and sounded like a 20 year old diesel transit van (aka a bag of spanners). |
