vibration at higher speeds?
07-26-2010, 11:17 AM | #1 |
Rep 47
every time im on the highway doing about 70+ my car seems to vibrate..any one have an idea on what it could be? also my front drivers side tire has a bubble in it..could that be the cause of it?
07-26-2010, 12:29 PM | #2 |
71
Rep 801
Yep. High speed vibrations are likely to be related to balancing. I would have my tires re-balanced. The bubble definitely sounds suspicious.
If it's not the tire/rim (I really think so) then it would be the control arm or some other component... Good luck. |
07-26-2010, 02:25 PM | #5 |
104
Rep 596
It can also be from a bent wheel (or wheels). I've driven through a number of rough roads, and they sure do a beating on our wheels, as well as alignment. Also examine your tires for any bumps. Try these after trying to rebalance/rotate tires first.
2007 BMW 335i, 2014 Audi A4, 2016 Acura MDX
Join us on Facebook: E90Post - Houston Houston BMW DIY Services |
07-26-2010, 08:12 PM | #6 |
Rep 47
no the steering wheel doesnt shake n the car doesnt pull..just my seats n radar detector vibrate pretty bad...its goin to the dealer on thursday so we'll see what they say
07-26-2010, 11:39 PM | #8 |
Rep 26
I'm pretty sure it's the bubble on your tire, www.e90post.com/forums/showthread.php?t=157293 you must have smoked a curb or something. There are steel wires inside of the tire that will get bent up on impact
07-27-2010, 04:41 PM | #10 |
AC
95
Rep 2,387
Your alignment could be off. Did you hit the curb before?
Your Supreme Leader
