Pipercross Airfilters
07-25-2010, 12:19 PM | #1 |
24 cans in a case, 24 hours in a day Hmmmmmm
79
Rep 1,152
Dont bother....I bought one of these a few weeks ago (163 engine, long cone type filter). Today being the first day I have had free I decided I would fit it, stripped the car and inserted the filter, air box wont close, so take the filter out, defo the right way round and defo in right regarding the lug and all checking fine, the box still doesnt close. Tries the old filter, box closes within seconds with no probs. Refitted the pipercross and the air box assembly still wont close tried to force it a bit to see if I could compress it slightly (end was catching) so I could get a tight fit and then rip...the end came right out the filter. £50 wasted.
I have been dealing with cars since I was 13 so fitting a filter is not rocket science and not new to me, compared to some of the other things I used to get up to, changing engines, gearboxes, heads etc etc, this should have been straight forward but no! On closer inspection, it would appear the filter is a diferent size, slightly taller so the end was always going to be under compression, so even if it did fit in it would have failed at some point. Will call them tomorrow see what they say, dont hold out much hope to be honest.
Present: G30 530D XD MSport
E84 X1 20D LUX |
07-25-2010, 01:18 PM | #2 |
118
Rep 2,216
Drives: E91 330d M Sport
Pipercross have sent me the wrong size filter in the past - if the live chat function is still on their website, it's worth asking before you do anything.
07-25-2010, 01:21 PM | #3 |
79
Rep 1,152
Didnt know they had that mate, thanks alot, appreciated!!
E84 X1 20D LUX |
07-25-2010, 01:32 PM | #4 |
79
Rep 1,152
Cant find the live chat, maybe its not there anymore. I know no one will be there but it was just for tomorrow.
E84 X1 20D LUX |
07-26-2010, 03:21 AM | #6 |
Rep 384
Drives: It's a Mini Adventure
Have used pipercross airfilters on previous cars in the past without any fitting problems.
Best talk to them and make sure you have the correct part. |
07-26-2010, 03:57 AM | #7 |
1867
Rep 13,043
Drives: BMW M340I G20
Only fair to talk to them directly, anyone can make a mistake.
07-26-2010, 12:37 PM | #8 |
79
Rep 1,152
Cheers for the advice guys, yeah I called them about 4pm tonight, explained to the chap what had happened and he requested I sent some pics, so I sent him one with a spirit level on top to show the height difference from the OEM one. I have had to go and buy a new OEM one today to allow me to drive the car as the old one is filthy and clogged. So I hope to hear from them tomorrow and see what they say. Will keep you posted.
E84 X1 20D LUX |
07-27-2010, 08:32 AM | #10 |
258
Rep 3,815
In past K&N have been nothing but trouble on cars with MAFs, I had loads of MAF issues with Focus and A3 due to too much oil on the K&N. Difference is K&N oil or use to oil both sides thus contamination of MAF with oil. Pipercross keep their filters very dry in comparison to avoid this.
F30 335i M Sport - now departed
07-27-2010, 09:27 AM | #12 | |
Rep 384
The main difference lies in that they still flow a similar volume of air after many thousand miles whereas the stock item is restricting air flow and causing a loss of power. Plus they can be cleaned so you will never have to replace the air filter again. |
07-27-2010, 11:21 AM | #13 | |
118
Rep 2,216
K&N guarantee that in the event of MAF failure due to oil contamination as a result of a properly oiled and installed filter, they will warranty all remedial work. So far, they've never had a substantiated claim, which to me suggests that anyone who actually has had MAF problems has probably over-oiled their filter. Maybe something to consider? |
07-27-2010, 02:40 PM | #14 |
258
Rep 3,815
wow thats new never heard of this - could be they changed something, I had issues with MAF from a new K&N already oiled from factory. After two mafs on an A3 I went to cotton green as could not get a pipercross quickly and had no problems after that,
Browsing A3 and seat leon forums came across a lot of people with similar issues, could be K&N changed design hence now offer the deal
07-28-2010, 02:25 PM | #15 |
Weekend Rockstar
39
Rep 728
had a K&N in my last 330d for 3 years and no trouble................
got one in my 335d now too..............!
E92 M3 - Interlagos Blue and Black everything else!!!
07-30-2010, 09:27 AM | #16 |
118
Rep 2,216
07-31-2010, 02:28 AM | #17 |
Zummerzet Zyder Drinker!
112
Rep 5,541
Drives: '06 330D Le Mans Blue
Not a fan of aftermarket max-power type filters!
08-01-2010, 03:13 PM | #18 |
258
Rep 3,815
sorry but they are not maxpower filters. Fact is they should not be looked as power increase items but but what they do is work at far better rate once you done 5k , 10k in them where a paper one drops off quite quickly as milage increases. Considering BMW now dont change the filters for something like 30k its crazy to keep paper one.
Yes you could change a paper one more reguallry but one bother works out cheaper just to clean a panel filter every 10k And its not marginal as it seems having number of times had to put back a paper one (spare old one in garage) while cleaning mine the difference was obvious. For example in my 150Bhp E46 320D it was case of huge clouds of black some under hard acceleartion or none when with pipercross. Both filters roughly having done 10k. So kind a does help
08-01-2010, 04:00 PM | #19 |
118
Rep 2,216
And given the scale of the job, changing an air filter in a 330d (someone's post recently) I can see a few 330d owners doing this too.
08-01-2010, 04:49 PM | #20 | |
79
Rep 1,152
Also, Ihave spoken with pipercross and expressed my concerns, they have told me to return the filter to where I bought it from for an exchange, so I do so and let you know what happens.
E84 X1 20D LUX |
08-02-2010, 07:58 AM | #21 | |
Rep 52
cheers |
08-02-2010, 08:29 AM | #22 | |
Rep 52
http://www.thepipercrossshop.co.uk/p...del=71&kit=389 |
