BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > E92 DIY D1S bulb Swap - 6000K
      12-28-2006, 09:24 PM   #1
Shinchan
LED Rules
Shinchan's Avatar
59
Drives: Sold: 335xi Coupe
Lightbulb E92 DIY D1S bulb Swap - 6000K
I just finish installing the new D1C bulb i received from ebay. They are McCulloch 6000K D1C bulb.
The new Bulb has a nice bluish tint to it.. but not as blue as my friend's 8000K.
Here are the tools needed:
8mm and 10mm socket wrench
t-20 Torex driver
new Xenon bulb
as any DIY... I'm not resposible for any breakage.... and make sure u remove the key from ignition. and light at off position.
1 Park the car at level place... and remove the front wheel...
LED Pimp...
13 Audi S4...
      12-28-2006, 09:26 PM   #2
Shinchan
LED Rules
Shinchan's Avatar
59
2. Start removing screws as i circle them in red.. there are quite alot of them you have to removed.. I took the pic in different angles...
LED Pimp...
13 Audi S4...
      12-28-2006, 09:29 PM   #3
Shinchan
LED Rules
Shinchan's Avatar
59
3. More screws to remove under the fender...
notice that the small rubber piece is secure by 3 screws. 2 in front and 1 behind.
there are also few more under the fender not show in the pic.. on the left...
LED Pimp...
13 Audi S4...
      12-28-2006, 09:31 PM   #4
Shinchan
LED Rules
Shinchan's Avatar
59
4. Use the t-20 Torex screw driver and remove the 5 screws on the Head light housing...
5. Carefully remove the cover.
LED Pimp...
13 Audi S4...
      12-28-2006, 09:41 PM   #5
Shinchan
LED Rules
Shinchan's Avatar
59
6. Unplug the power from the bulb.. by wiggle it and gentally pull it downward.
7. Unhook the 2 clips holding the HID D1S bulb in place.. by carefully push it down and slide them inward..
8. Remove the OEM bulb and replace it with new bulb.
9. Re-secure the bulb with the clips
10. make sure again the power plug is secure plug back in.. as far as it go.. you should able to feel the click it it goes in.
11. start up the enging to make sure the new bulb can be lit up.
12. Remove the key from the car.. to make sure no power goes to HID.
13. Reverse all instruction... and put the fender back in. (Start the fender by the top... slide the top in first.. then when you are very close to fit in the buttom, you will need to slide them in in an angle...)
14. Admire your accomplishment....
LED Pimp...
13 Audi S4...
      12-28-2006, 09:42 PM   #6
Shinchan
LED Rules
Shinchan's Avatar
59
Here are 2 pictures...
LED Pimp...
13 Audi S4...
      12-28-2006, 09:46 PM   #7
Shinchan
LED Rules
Shinchan's Avatar
59
AS far as some questions goes.. did i loose some brightness?
Hard to tell.. coz.. I also re-adjust the angle of the HID by counter-clock 2 full turn to make them aim a bit higher.. so I can't tell if the light dim abit.. but that 2 full turn make some nice distance on HID.
and its also a bit bluer then my other car... (Phillips D2S 6000K bulb in my FX35)
LED Pimp...
13 Audi S4...
      12-28-2006, 10:50 PM   #8
youyou
youyou's Avatar
92
Drives: Porsche 997 C4S
So since you say there's blue light do you think they would look better with the Mtec Cosmos Blue or the Mtec Super White?
I am trying to get some sort of contrast between the two...
      12-29-2006, 08:04 AM   #9
Shinchan
LED Rules
Shinchan's Avatar
59
can someone post their Cosmo BLue angel here? so we can compare?
LED Pimp...
13 Audi S4...
      12-29-2006, 09:23 AM   #10
dmboone25
dmboone25's Avatar
4972
2007 E92 328i  [10.00]
2007 328i  [10.00]
Looks good! Very impressive.....
      12-29-2006, 12:24 PM   #11
Kalin
11
Drives: F31 328xi
Stock Xenon w/ Cosmos Blue angel eyes.
      12-29-2006, 01:54 PM   #12
dmboone25
dmboone25's Avatar
4972
2007 328i  [10.00]
Those angels don't look nearly as bright as my Super Whites--are they on in this pic? Or am I nuts?
      12-29-2006, 01:59 PM   #13
Shinchan
LED Rules
Shinchan's Avatar
59
look at all his light source.. he took the pic with fast shutter... so its much dimmer..
LED Pimp...
13 Audi S4...
      12-29-2006, 05:52 PM   #14
Kalin
11
Drives: F31 328xi
Yes, 1/100, F/2.8. In person they are very bright.
      12-29-2006, 07:05 PM   #15
dmboone25
dmboone25's Avatar
4972
2007 328i  [10.00]
I'm sure they are very bright--it is just hard to see the blue--but regardless, they do look nice.
      12-29-2006, 07:19 PM   #16
youyou
youyou's Avatar
92
Ya i see no blue whatsoever...
And i was set on buying these now i'm more confused then i was before...
Cosmos Blue or Super White
      12-30-2006, 03:54 AM   #17
Kalin
11
Drives: F31 328xi
They are not a strong blue by any means. The container says 4750k which is still in the white arena. For a real blue color you'll have to go a lot higher, like what Shinchan is trying to do to match the 6000k xenon.
So if you are looking for blue angel eyes, these are not your answer. And the Cosmos should be more blue than the Super White.
      12-30-2006, 04:02 PM   #18
dmboone25
dmboone25's Avatar
4972
2007 328i  [10.00]
Good info!
      03-12-2007, 08:54 PM   #19
f16pilottmo
Drives: 2006 325i Sedan
Question Kaixen 8,500K Bulbs
Should I try to put these in my car, or is that too much? Also, I have an 06 E90 325i Sedan
      03-12-2007, 09:11 PM   #20
ironic
ironic's Avatar
254
Drives: Jet Black 335i
very nice
Widebody 335i Project Car BUILD | PHOTOSHOOT
      03-12-2007, 09:17 PM   #21
ehhhwik
ehhhwik's Avatar
Hong Kong
114
Drives: 09' BMW 335d, 07' BMW E92 328i
PM'd
Current: 09' E90 335d - Titanium Silver/Black Leatherette/Sports Package/6AT Paddle Shift/USB Integration/19" Staggered Breyton GT Gloss Black
Retired: 07' E92 328i (Jet Black)
      04-25-2007, 09:21 PM   #22
muvaside
muvaside's Avatar
18
Drives: E90 335i
Thumbs up
Nice DIY write-up
