My first long crank.....fluke or should i be worried?
07-19-2010, 11:39 AM | #1 |
5478
Rep 8,823
So my 2009.5 msport 6MT with 6200 miles did its first long crank yesterday. Instead of taking 2 seconds to fire up it took maybe 4-5...def. longer than usual.
I turned off the car and restarted it again without any issues and the drive drives normal as far as i could tell. Power has been down in general in this crazy NY heat wave (95+ and humid as hell). I scanned the car with the BT tool and zero codes came up except for 00A4 which isn't related but I also can't clear it for some reason. Should i be worried or is it consider normal for these cars to have a somewhat longer crank than usual from time to time? Wonder if this heat could have anything to do with it. Mods = JB3 1.4 map 5, Injen dci, RPI exhaust Alan
07-19-2010, 12:22 PM | #3 |
398
Rep 4,084
if it was 1/2 a second id say no biggie. but for 4-5 seconds i'd call a dealer and be prepared.
7/18/09- I pick up my baby- 2009 E92 335i Xdrive, Space Gray over Coral Red. Premium Pkg, Cold Weather Pkg, M-Sport Pkg, 193Ms, Gloss Black grills, Custom Gloss Black Mirrors, Performance shift and E-brake boot, M3 spoiler, Euro fog switch, gloss black interior tim, Coco-Mats (red/black), H&R coilovers, 19'' Alufelgen SF-71s......
07-19-2010, 12:34 PM | #4 |
Former N54 Fanatic
84
Rep 1,927
Drives: Slow
Eh, nothing to worry about until you start seeing fuel pump codes.
07-19-2010, 12:48 PM | #5 |
23
Rep 1,179
an occasional longer "than usual" crank can happen .. i'd start being alarmed if it continued .. like two or three times a week ..
do you drive the car on a daily basis?? is it garaged?? not that it should matter-- just a question mine is used to be garaged and hardly ever driven on the weekends .. just looking to get a picture of maybe up ahead ... mine still starts ok at this point.. 13k |
07-19-2010, 12:51 PM | #6 |
3441
Rep 79,211
Ive been having on and off long cranks since Feb. Its the luck of the draw.
Some just do it, others need replacement sooner or later. Just be prepared, there is no concrete yes or no anymore, especially with no codes. |
07-19-2010, 02:14 PM | #9 |
5478
Rep 8,823
From my understanding Map 5 is fine as long as you run 93 octane gas which is the only stuff i put in this car.
Hopefully this isn't a sign of things to come....
07-19-2010, 02:47 PM | #10 |
314
Rep 3,262
Sorry for your loss...there is no escape
07-19-2010, 02:49 PM | #11 | |
Me
12
Rep 246
...i took the car right to the dealer, and then got a message from my tech saying it WASNT my fuel pump, but was actually my low pressure fuel sensor, and crank sensor.
Dan
Scuderia Ferrari Marlboro |
07-19-2010, 02:57 PM | #12 | |
Me
12
Rep 246
Dan
07-19-2010, 04:33 PM | #15 |
Keepin' America Free
72
Rep 1,260
I had two long cranks last week... got me thinking but everything else has been fine. Hopefully it isn't anything major.
F10 535i | Retired: E60 ///M5 | E92 335i
"If everything seems under control, you're not going fast enough" -Mario Andretti |
07-19-2010, 04:41 PM | #16 |
5478
Rep 8,823
do you guys usually press on the start button once so that the dash lights lights up....then press it again to start the car or just hop in and start right away?
I know for my old car (suby) people use to do that to sorta allow the fuel pump to prime itself before actually starting the car. I've always hopped in, press on the clutch and start right away with this car. Alan
07-19-2010, 05:12 PM | #17 | |
23
Rep 1,179
07-19-2010, 05:19 PM | #18 |
The Moose Whisperer
22
Rep 406
To the OP and others with similar symptoms, you better start looking through the 'HPFP Sized' Casket catalog now, it only goes down hill from here....My condolences......and No, you don't necessarily need to have any CEL's or Half-engine lights come on prior to your pumps dying. I'm on my 3rd in 20k miles and none of them produced any dash-visible warning signs, they just....died. If it gets to the point where the 4-5 sec. cranks become the Norm, don't wait for the Hard codes to be thrown, bring it in Asap and there should be enough evidence of a failure for BMW to recognize whether or not the pump is worthy of replacement or not. Give it a week or 2 to be safe of the prolongued Cold-Starts and then try. GL
~Chris~ |
07-19-2010, 06:21 PM | #19 |
ElevenPointFive
326
Rep 2,450
I have a longish (3 seconds max) crank in the morning once every 2-3 weeks. Don't not start the worrying yet, hold out hope!!!!
2008 E90 335xi - N54 Daily Driver
MHD Stage 2+ ~ CPE DPs ~ BMS Intake ~ AMS FMIC |
07-22-2010, 02:14 PM | #20 |
102
Rep 780
Alan, bring it into the dealer for long crank complaint. 135, 335 & 535's come into dealerships for this issue all day long. Sometimes it wont throw any faults. The intergration level of your car is probably outdated. There's a bulletin for that issue to get a DME program update.
07-22-2010, 04:36 PM | #22 |
40
Rep 199
O.
