BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Brake, ABS, Tire Pressure, etc. Warning Lts
      07-16-2010, 01:43 PM   #1
aweesner
Drives: 2006 330i
On Sunday a whole host of warning lights suddenly lit up...
- ABS
- Tire Pressure
- Hand Brake
- Triangle with circular arrow in center
They have all been on since Saturday with the exception of one time on Wed night.
The car seems to be operating fine.
I'm not sure if this is relevant but we had super heavy rains here in Boston on Saturday and I drove through some 6-8" puddles.
Any ideas on what is going on?
      07-16-2010, 01:55 PM   #2
RFGuy_KCCO
RFGuy_KCCO's Avatar
82
Drives: 2022 X3MC BSM/SO
One of your ABS wheel speed sensors has probably gone bad.
      07-16-2010, 02:46 PM   #3
Edward
377
Drives: 2013.9999 E92 Jerez ZCP
Not sure but don't drive it. If you had a battery light come up too, I'd say your alternator is real close to eating crap.
      07-16-2010, 02:50 PM   #4
Chriztofor
Chriztofor's Avatar
103
Drives: '06 325i and '13 X5
- ABS
- Tire Pressure
- Hand Brake
+1 on the speed sensor, also see my sig.
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
      07-16-2010, 03:20 PM   #5
orangedawg
31
Drives: 328xi
It might need a wheel bearing. IIRC, there is the wheel speed sensor which goes in to the knuckle that reads a magnet that is part of the wheel bearing. Is that correct?
      07-17-2010, 01:30 PM   #6
pruettfan
1622
Drives: 2017 M2, LBB, DCT, Exec
This is a common issue on 2006 330i's. I have had it and have shared my story with several who have and it helped them resolve the issue. It is highly likely you have a bad rear wheel bearing and abs sensor. I had to take my car in two times to get my dealer to figure it out. They ended up sending data to BMW who told them what was wrong. The error codes they will see will not tell them it is a wheel bearing. In fact on my first visit they decided it was a bad battery. Of course they were wrong. The repair is about 800 bucks if you don't have a warranty. You can try just changing a wheel sensor but if that does not fix it then it is a wheel bearing.
Tom
      07-17-2010, 02:41 PM   #7
caseybc
Average Member
Drives: 335i M sport
wheel speed sensor. relatively cheap fix.
      09-22-2012, 05:48 PM   #8
Kokekan
Drives: E90 330D M Sport
Hey Tom, how did they find out which corner the wheel bearing was faulty on? Did they have to read the speed sensors?
