07-13-2010, 09:52 AM | #1 |
22
Rep 116
Why am I only getting 11 to 12MPG in my 128i?
BMW claims the the 128i coupe should get 18mpg city. I am by no means driving in the city. In my suburban area I do stop and start a bit on the way to work in my 2011 128i coupe with 6MT. However, in my opinion not enough to justify 11 to 12mpg. What is going on!?! That is horrible! Is the MPG computer messed up? I would think I would even get slightly better gas mileage with the 6MT. Since I am still in the break in period, I have yet to even rev it above 4K.
In my 528xi with the same friggen engine, I get 22mpg driving the same roads and distances, and that's with an automatic and AWD. I also noticed that i get 450+ miles between fill ups in the 528xi verses less than 200 in the 128i. Could partly be the tank size, but I doubt the tank is half the size, and it costs me about the same to fill up at the pump in the 128i. Anyone else experience this abismal gas mileage in the 1 series? Hosestly, I didn't buy the car for it gas mileage, but this is really surprising. |
07-13-2010, 10:03 AM | #2 |
27
Rep 304
Thats some bad gas mileage... must be something wrong or you are driving it at 6000 rpms ALL THE TIME.
I drive mine fast and regularly take it to 6000 rpms and I manage 25 mpg. I usually keep my cruising rpms to 2000... There should be an average mpg that you can reset and there should be another mpg option that gives you a constant read out of your current mpgs... trying reseting the average mpg or switching to the current mpg read out and see what it says.
Ordered: 128i Titanium Silver, Black Leatherette, High gloss black trim, Sport Package, iPod Adapter, Premium Audio, BMW Assist
07-13-2010, 10:09 AM | #3 | |
22
Rep 116
07-13-2010, 01:51 PM | #4 |
124
Rep 5,627
While the later model BMW computers are pretty accurate, you need to calculate your true mileage and average it over several tanks.
Every time you fill up, note the miles travelled and reset your trip odometer. Note the gallons used. Divide the miles by gallons to get mpg. Also, reset the BC MPG readout at the same time and compare that reading to your calculation - this will give you the percentage of OBC error. Having said all that, break-in mileage is not representative of what the car will achieve later on. I get about 18~19 in city traffic, around 22 in suburban traffic and 28~32 on the highway - about 10% less when using air conditioning. Also, running 87 octane rather than 91 or 93 is likely to hurt your mileage by 5~10%. If your true, calculated mileage is still at 11~12 after break-in, you may wish to discuss it with your dealer. Tom |
07-14-2010, 09:58 AM | #5 |
22
Rep 116
Alright I admit it. I'm a noob! The guage was set to kilometers! I guess you have to set this guage independantly of the other language and measurement settings. It is now reading 18.9 on average, which is much more reasonable.
07-14-2010, 01:31 PM | #6 |
91
Rep 1,168
I thought my 135i is bad at ~16MPG, so something may not be right. Calculate your own MPG as suggested above and compare with the computer readout before taking it to the dealer.
EDIT: I see you discovered the problem! It makes better sense now... |
07-14-2010, 02:52 PM | #7 |
12
Rep 123
still 11 litres per 100 kilometers is pretty bad. I do some spirited driving in mine and the worst I have even seen is 10 litres per 100 averaged out. My average is usually 9 litres/100km combined city and highway.
07-14-2010, 05:53 PM | #8 |
NCO
13
Rep 641
I have to say that's very surprisingly low! I've got a 2010 135i MT and my overall average with only about 4k miles on the clock is 23.5 mpg. Driving around town is pretty low, but on the highway even at 3K rpm, I've averaged 25-26 mpg.
FWIW, I've checked every fill-up separately with an iPhone app called Road Trip and the overall average is spot-on with the OBC's average mpg. I was surprised it was that accurate. Regretfully, I'd suggest taking it into a BMW dealer. pge |
07-16-2010, 02:15 PM | #10 |
22
Rep 116
I think you misread I am the OP. I am getting 22 in my 5 series. It's the lower MPG I am getting in my 1 series that was the concern. However, I figured out that my measurement setting was set to Kilometers not miles. It's still not as good as my 5, but I am getting 18 to 19MPG now.
07-16-2010, 04:59 PM | #11 | |
124
Rep 5,627
Now if it is kilometers per gallon, then that would equal about 3 miles per gallon and you'd have a real problem - but I never heard of fuel consumption quoted this way. Tom |
07-17-2010, 08:53 AM | #12 |
19
Rep 349
Not to be rude, really - but you ought to do an actual test of miles traveled versus fuel used before believing any electronic device. I drive very aggressively, 70% non-highway and get 19 mpg overall. On trips, high 20's.
07-20-2010, 10:05 AM | #14 |
15
Rep 885
Drives: 25 to 2
i wouldn't waste a trip to the dealer. The car is still new, and based on your driving, that is reasonable.
2010 135i - Alpine White - Coral Red- Glacier Trim - Bluetooth - ///M Sport - Paddle Shifters
07-20-2010, 10:21 AM | #15 |
Resident Kerbalnaut
477
Rep 10,703
I noticed that this car took about 25,000 miles to fully break in. I was averaging about 18-19 mpg in the beginning. Now I drive the car much more enthusiastically and I average about 23-24. When I try I can get about 35 mpg highway with the top down. And if I really really work at I can push that number up to about 40
07-20-2010, 10:28 AM | #16 |
Resident Kerbalnaut
477
Rep 10,703
Here's a link to a thread I made after a long road trip with mixed driving (highway and fun mountain back road)
I got about 33 mpg on that trip and it's not uncommon http://www.1addicts.com/forums/showthread.php?t=325253 |
07-20-2010, 02:12 PM | #17 | |
91
Rep 1,168
07-22-2010, 07:59 AM | #20 |
24
Rep 179
I kept a notebook for every fill-up for the first year. Now I'm using Fuelly.
It is possible to get great mileage in the 128i: http://www.fuelly.com/driver/ribimmer/128i
07-22-2010, 05:04 PM | #21 |
28
Rep 90
I thought I was the only one getting poor gas mileage. Honestly, with the new tougher rating system the EPA has, I find BMW numbers lofty. I'm about 22-23 when I take it easy.
But then I checked the epa website. Nope Normal: http://www.fueleconomy.org/FEG/noframes/25836.shtml Fuel Type Premium MPG (city) 18 MPG (highway) 28 MPG (combined) 21 |
07-22-2010, 05:11 PM | #22 | |
Unindicted co-conspirator
66
Rep 1,734
Drives: to work, mostly.
Average 29 MPG??!? What are you doing to achieve that, dare I ask? |
