07-12-2010, 02:03 PM | #1 |
73
Rep 725
Cleaned the air filter yesterday
After 11,000 miles, I felt the car just didn't have the same pickup it used to have when it was new. While looking things over under the hood, I decided to inspect the air filter. Turns out it was jam packed with leaves, bugs, and brake dust. Isn't the dealer supposed to check this during any of the scheduled maintenance? Anyway, shook it all out and blew it with some air and put it back. It made a noticeable difference in the throttle response and get-up-and-go Stupid bugs.
Mmmm... M&Ms,
Dale |
07-12-2010, 02:44 PM | #3 |
73
Rep 725
Replacing is not the same as cleaning. It should be cleaned way before 11,000 miles. Not sure when replacement is scheduled, but I'm sure it should be cleaned several times well before then.
Mmmm... M&Ms,
Dale |
07-12-2010, 02:49 PM | #4 | |
BimmerPost Supporting Vendor
8067
Rep 18,788
Drives: BMW
07-12-2010, 03:48 PM | #6 |
218
Rep 2,339
The OEM filters aren't really considered serviceable. Its not something that they remove, clean and replace. There is a scheduled replacement and that's when they look at it. Otherwise, they won't touch it unless you tell them something is wrong with it.
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
07-12-2010, 03:56 PM | #7 |
73
Rep 725
Ok, then consider my OP something to consider trying if BMW won't do it until it's time to replace. That's rediculous. My filter was absolutely clogged, and I was missing out on performance. I'm surprised BMW wouldn't provide the service to keep up the performance of their customers' cars, after all, it only takes a few minutes.
Mmmm... M&Ms,
Dale |
07-12-2010, 04:07 PM | #8 |
8067
Rep 18,788
Drives: BMW
07-12-2010, 04:41 PM | #9 | |
218
Rep 2,339
BTW, if you get an MS filter, you can clean it whenever you want. Problem solved!
07-12-2010, 06:57 PM | #10 |
73
Rep 725
I consider the 1200 mile visit a scheduled service. Plus, it was in several other times for various things (500 mile oil change, DCT reprogramming, tires and brake pads at 6700 miles, and broken trim piece). So that's five visits total. All I'm saying is, it's such a simple thing for them to check that I'm surpriosed they don't do it as a courtesy. Plus, it's made enough of a difference that I could feel it.
Mmmm... M&Ms,
Dale |
07-13-2010, 02:38 AM | #12 | |
218
Rep 2,339
Bottom line, if you want them to do something, just ask for it. Most techs are more than willing if you just ask politely. Don't take it for granted that it will be done because that's what you would do because as much as they would like to help you, they are busy people too and in the end, they wanna go home on time to see their families just like you and me.
07-13-2010, 05:18 PM | #13 | |
2011 E92 M3
33
Rep 432
2011 E92 M3 6MT
Gone - 2007 E90 335i |
07-13-2010, 09:15 PM | #14 |
124
Rep 4,145
We have a big ole air scoop below and ahead of the front left wheel. All sorts of things get sucked in there. I clean mine out (just take it out and shake it, no air blowing) when cleaning up the engine compartment on average about every month or little more often. It seems there's always leaves, plastic and what not. So far, nothing very interesting like dead cats.
It only takes a couple minutes so it's no problem, and yes, you can feel a, albeit slight, difference when it's clean. Unless you have a totally have a "hands off" attitude about working on your car, I recommend this. A little work putting the cover back on, but still very easy. I'm thinking about getting an oiled filter since I'll be coming to the end of free maintenance soon. Cheers.
2017 F80 YMB.
12-29-2010, 06:55 PM | #16 |
Rep 25
BMW performs same at every oil change per the maintenance guide they did mine at the 1200/2000km change too
It's a filter it depends on environment dusty environments being more frequent than non.
E92 2008 M3 Coupe
Eibach Pro-Kit Springs Active Autowerke short-shifter Carbon-Fibre everything |
12-30-2010, 11:27 AM | #17 |
256
Rep 5,012
BMW doesn't touch the air filter until 30K miles. And that's exactly what my '08 service booklet calls for. And yes, with a straight big opening in the bumper, it's nuts to wait that long IMO, especially if you live in the dusty desert.
02-19-2018, 10:14 PM | #18 | |
100
Rep 144
I'm running a stock intake and filter set up. Every time my car starts to feel a little sluggish, I take out the air filter and tap the dirt out of it, and every time my throttle response is noticeably improved. Even as little as 3000 miles seems to get the filter a little clogged. I then replace the filter every 10k miles. If you've never tried tapping the dirt out of your air filter, do it. Old thread, I know. |
02-20-2018, 12:05 AM | #19 |
11575
Rep 12,714
if you're going to go through the trouble of opening the box and removing a filter to knock the bugs out of it, just replace it.
Instagram; @roastbeefmike
02-23-2018, 10:19 AM | #20 | |
100
Rep 144
I'm looking into aftermarket filters but am very skeptical of their filtration capabilities. |
