07-12-2010, 02:30 AM | #1 |
13
Rep 254
DIY: No Holes Front License Plate (no tow hook)
I didn't come up with this clean, cheap, yet very effective solution to a front license plate with no holes. Since it took a while to search and find these posts, I'm going to link them all here.
The original post by khaye1: http://www.e90post.com/forums/showthread.php?t=374893 Here's a pic of my fake plate (still waiting for the real one). What you need? 1. Bell / adjustable license plate mounting bracket from Autozone...$8.99 2. Two (big yet small hole) washers from Home Depot...$0.40 3. Might need some padding on the back of your license plate so that they don't scratch the bumper (I haven't got to this part yet since I have fake 'plastic' plate). I was able to pop off part of the bottom grill but it was still too much trouble to put on the washer. So I had to take off the bumper which was a pain in the ass to put back on but it was so worth for a noob like me. You might need a 2nd pair of hands for this. Here's the DIY for the front bumper removal: http://www.m3post.com/forums/showpos...69&postcount=3 You do not have to take off the full bumper. I recommend taking off the passenger or driver side part of the bumper to place your arms behind it. It's pretty easy from their on. If you don't want to take the bumper off, then you can drill the bottom of it like frankie did in his post: http://www.e90post.com/forums/showthread.php?t=378549 |
07-29-2010, 08:23 AM | #2 |
CEO
Rep 11
Here's a easy fix what I did not havin to mess with takin things apart.
Just take the nut and washer & solder them together with acid core solder & small torch, than solder small wire , I used baling wire to the washer bend wire to feed throught back side of grill attach bolt from front and than trim wire & bend out of sight and there u go easy hope this helps! Mark B. |
05-20-2011, 07:23 AM | #3 |
OIF Veteran
246
Rep 2,106
if you really wanted to be extreme, you could take off your front bumper, put magnets on the back side where the license plate would be. Then put magnets on the license plate.
This way you have a magnet plate mount, and can remove the license plate anytime you want.
Retired: '06 BMW E46 ///M3
Current: '08 BMW E60 DINAN ///M5, Interlagos Blue, SMG DINAN Stage 2 Suspension, Exhaust, Stage III Software, Front strut braces, Intakes, 13% Underdrive pulley, 3.91 Differential, RPI Scoops. |
05-21-2011, 12:15 AM | #4 |
258
Rep 5,012
Just use the original bracket people. It's secured with 2 bolts under the bumper, completely invisible. And rather than drilling the bumper for the upper 2 bolts, just put double-sided tape behind the bracket and it won't go anywhere. Or bang anywhere. And it already comes body-colored .
08-07-2012, 02:00 PM | #6 | |
58
Rep 717
08-07-2012, 02:01 PM | #7 | |
58
Rep 717
08-07-2012, 02:26 PM | #8 | |
866
Rep 6,248
05-21-2013, 06:37 PM | #9 |
Rep 91
Anyone know whether removing the front kidney grille(s) will allow for a hand to go reach down and position the rear washer/nuts?
E92 M3 6MT ZCP
05-22-2013, 07:38 PM | #10 |
20
Rep 111
i think it would be easier to use spring toggle wing bolts and insert them thru the holes in the mesh instead of taking apart the grill or bumper.
https://www.google.ca/search?q=Sprin...-a&channel=rcs Last edited by crunchy_frog; 05-22-2013 at 07:45 PM.. |
