Codes 2F71 & A8AF ???
07-10-2010, 01:53 AM | #1 |
95
Rep 2,160
Anyone have any ideas whats causing these codes?
I reset using the BT tool and after I restarted the engine and rescanned the faults came back 2F71 - Ebox Fan Input Signal A8AF - Footwell Module A8AF - Rain And Light Sensor None of these codes trigger and warning lights... Should I be concerned about any of these codes? Also someone told me the engine has to be running to scan using the BT tool but I was able to scan for faults with just the key fob inserted. Should the engine be running when using the BT Tool? Thanks |
07-10-2010, 02:34 PM | #3 |
Rep 76
I believe the codes that start with an "A" are light codes. The JB3 is my only mod and I never have engine/tuning related codes. One day I had a "light out" warning pop up on my dash and when I BT'd the car, I had several "A" codes pop up. The goofy thing is that none of my lights were out. I searched around on the forum and found that there is an SIB (service bulletin) from BMW stating that there is a known issue with our tail lamps/lamp socket. The warning lights pop up but no lights are out and this is caused by vibration. There is a fix for this at the dealer where they will install some foam pads on the housing to dampen the shock. Not sure if it works as I've yet to take mine into the dealer.
07-10-2010, 03:20 PM | #4 | |
95
Rep 2,160
Yeah I wasnt too concerned about the "A" Footwell Module code... But the 2F71 is an engine fault so I'm wondering if its something I should go get checked out... I searched the forums but I seem to be the only person that has ever mentioned this code |
07-10-2010, 05:43 PM | #5 |
Rep 76
I've seen that code on a friends 335i that I've BT'd a couple times. I'm told there is a fan in the electrical box (ebox) where the ECU and the JB3 are located. I've never looked for it but have heard it mentioned a few times. I think I've read that the fan blows into the cabin through the firewall to keep the ebox cool. Did you run the jb3 cable into your glove box through the firewall? If you did, maybe something happened to the fan during the install.
07-10-2010, 05:49 PM | #6 | |
95
Rep 2,160
Thanks! |
