Dyno numbers discussion - some questions..
07-05-2010, 12:07 PM | #1 |
273
Rep 5,876
Never ending quest in understanding the power my car makes under load. Given this latest chart and looking at all other charts I feel there's 3 things that I'd like to discuss and understand why:
1) Torque spike at 4400..I'm aware of the VANOS shift there but it seems most current dynos don't exhibit this spike anymore. It used to be there before on V2 AFAIK but think you've done something to smooth it out. Any idea? 2) Why would the curves be so jiggly after 4000rpm? Is this indicative of a boost leak? Most other curves I've seen, even comparing to other N54s on the same dyno (Irishace, gian335, luca335) don't show as much jiggle...what could this be? Think its present on valet mode map (stock tune) with my boltons... 3) whp and wtq curves intersect at ~5200rpm when they should do that at ~5600rpm. Could all these problems above related to something common? Any thoughts/advice on what to check for? The car's been running really good since I managed to replace all injectors, plugs, latest bmw software and fix a boost leak on the inlet side to the FMIC (pipe was slightly off). I'm still on the original HPFP (75,000 km), 1 relatively long crank in the last 2 months but other than that pretty solid... FYI: Dyno was done on all stg 3 catless boltons + procede v4 5-15firmware, 50/50 meth and pump 94 gas, procede set for UT 85, 0 ign correction |
07-05-2010, 12:18 PM | #2 |
Just1MoreMod
354
Rep 712
don't know about 1) and 2), but all torque and horsepower numbers intersect at 5252 rpms.
Stage 3 - Pure Turbo F80 M3
Dinan Infested F48 X1 |
07-05-2010, 12:30 PM | #3 | |
1743
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Other thoughts I had were emailed to you. Shiv Ps... Didn't u run 121mph trap speeds after these dyno runs? I would put more weight in that than dyno numbers due to all the factors than can/could have come into play on the dyno. |
07-05-2010, 12:50 PM | #4 | |
273
Rep 5,876
2) Why the 4400 torque spike? I can readily reproduce this any time on any Dynojet... Car dynos 272whp/286wtq on the stock tune but with all boltons + catless with the same jiggles in the curves after about 5K rpm. So to start out (stock tune) the numbers are lower than avg for this "specific" dyno and these mods by about 20...If this is happening on the stock tune (proceed valet mode) I'm wondering what it could be mods related given boost leaks aren't evident through any codes/logs... could it be maybe carbon build up on the valves on the exhaust side or ??? 3) If you look at many recent dyno plots on this forum you'll see whp/wtq curves actually intersect at 5500rpm and power climbing steadily to about 5500 while on the chart I provided you can see the power start to go horizontal a few hundred RPM earlier.. If we take the hp equation of: whp = (wtq*rpm)/5252 and consider the torque curve posted above a better question would be why is torque falling off so quickly past the torque spike at 4400RPM (vanos shift)? Maybe addressing this would help? I had my vanos solenoids changed at the dealership about a year ago and its in this timespan that this mystery has manifested itself...however, i recall (and have charts) showing this spike at the VANOS shift from soon after I originally got the car so it seems its always been there.. Last edited by dzenno; 07-05-2010 at 01:02 PM.. |
07-05-2010, 01:04 PM | #5 | |
273
Rep 5,876
07-05-2010, 01:05 PM | #6 | |
1743
Rep 17,960
Drives: A Lot
If you want to rule things out, do this: 1) Pressure test your induction system. To 20psi at least. That will rule out a boost leak. 2) Dyno test with race gas with a 75/25 mix. That will rule out knock retard CAN logs only show cyl 1 ignition advance. For all we know, cylinder 2-6 aren't running full boost. Very very unlikely but it's possible. 3) Inflate rear tires to 50psi. This will rule out tire-induced frictional losses. 4) Make sure the dyno straps are on tight. This will rule out the car rocking back and forth during the run. Without doing all these, we could be guessing forever. Shiv |
07-05-2010, 01:08 PM | #7 | |
273
Rep 5,876
As to your point about cyl 1 ignition advance, is it safe to say that bank 1 is fine then because if there was a timing drop in any of the cylinders in that bank it'd manifest itself in some sort of a drop on cyl 1 as well a few rpms later, although not as much, as DME would try to keep balance there...but if this timing dropout happend in a bank 2 cylinder we would be less likely to see this in that cyl 1 timing datalog? |
07-05-2010, 01:12 PM | #8 | |
1743
Rep 17,960
Drives: A Lot
Shiv |
07-05-2010, 01:16 PM | #9 | |
273
Rep 5,876
In any case, I'll do a prep on the points you raised above and re-dyno soon.. |
07-05-2010, 01:17 PM | #10 |
133
Rep 4,764
Nice torque numbers. Interesting that I saw 390whp with 93 octane (no meth), but much less torque with the 10-09-2009 maps at only 14.8 PSI.
With Meth (72/25) and 17PSI, with 93 octane, I am hoping for 420whp. Thanks for sharing. |
07-05-2010, 01:20 PM | #11 |
273
Rep 5,876
basically how do I get a dyno curve this smooth with no spikes?
http://www.e90post.com/forums/showth...t=procede+dyno EDIT: He did run 101 octane and 75/25 meth..but no 4400rpm torque spike... |
07-05-2010, 01:23 PM | #12 | |
1743
Rep 17,960
Drives: A Lot
shiv |
07-05-2010, 01:25 PM | #13 | |
1743
Rep 17,960
Drives: A Lot
Shiv |
07-05-2010, 01:29 PM | #14 | |
273
Rep 5,876
P.S. By the way, just looked at my JB3 2.0 dyno and the spike is there even with the JB3 running 15.8psi boost peak on 94 octane, no meth. EDIT: This was a different DynoJet, just illustrating the spike presence on a different dyno as well.. |
07-05-2010, 01:55 PM | #15 |
1743
Rep 17,960
Drives: A Lot
Look at the difference between the spike with the two tunes. With the procede, it's not a spike. Look at the hp curve and it will be more clear. Seriously man, re-dyno after following my suggestions. And then let's discuss.
Shiv |
07-05-2010, 02:05 PM | #16 |
273
Rep 5,876
Actually if you look at run #16 in the first chart above which was proceed + no meth + pump 94 at the same boost level as JB3 you'll see there's a spike in whp as well with the procede...
I didn't dyno jb3 2.0 with meth and higher boost so don't know what would it would've looked like... |
07-05-2010, 03:46 PM | #17 |
ElevenPointFive
326
Rep 2,450
I have the exact same vanos blip at 4400 rpms on my dynos. The only difference on my dynos is that my torque curve does seem to be a touch smoother, but only marginally and it drops off about 500 rpms later than yours.
2008 E90 335xi - N54 Daily Driver
MHD Stage 2+ ~ CPE DPs ~ BMS Intake ~ AMS FMIC |
07-05-2010, 03:56 PM | #18 |
ElevenPointFive
326
Rep 2,450
I also would agree with Shiv, your real world performance under load is pretty staggering, trapping 121mph is no joke. You accomplished this without the combo of race gas and 100% meth. You can easily push another 2-3mph when doing this. Your car is a horse
07-05-2010, 04:02 PM | #19 | |
273
Rep 5,876
i'll follow the direction given above, prep the car with MS109 and 75/25 meth, pressure test the system at 20psi and once I get all those in check I'll go for a redyno |
07-05-2010, 04:12 PM | #20 | |
ElevenPointFive
326
Rep 2,450
07-05-2010, 04:15 PM | #21 | |
273
Rep 5,876
Really what I'm after here is why on the stock tune/boost (map0 for jb3, valet mode on procede) i put down only 272whp/286wtq with full boltons catless DPs/exhaust...This would mean that without them I'd be at 245-250whp stock which is approx 25-30whp lower than avg... what did you dyno stock with your boltons at Champion Motors (map0)? have that chart to share? EDIT: I actually ran 80/20 meth mix with MS103 when I ran that 121mph...just checked my old post for details... Last edited by dzenno; 07-05-2010 at 04:37 PM.. |
07-05-2010, 04:37 PM | #22 |
161
Rep 7,377
I dynoed exactly the same as you on stock boost fully bolt on (stock turbos) and 251 completely stock.
You cant compaire to what other people dynoed. Important you keep doing them at the same place to see the delta and differences.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
