front suspension noise
07-01-2010, 11:18 PM | #1 |
Rep 49
whenever i go over speed bumps my car makes noises like a worn mattress. i am the first and only owner so i know the car has been driven very easily over bumps. and the car has about 82k miles on it. has anyone else experienced problems with their front suspension? i know the tires arent low either because i just checked them so it cant be that. it only makes noises on the front of the car.
07-02-2010, 07:57 AM | #4 |
173
Rep 3,415
My car used to make this noise too. I traced it to the accordion boots that cover the strut pistons on the front struts. On my car the boots are detached from the lower connection on the strut (near the lower spring mount). Look into the wheel well atop of the tire and look to see if the boots have detached. I think over time the rubber boots shrink and become loose.
09-14-2010, 02:30 AM | #5 |
Rep 248
My car's done it since it's first fall in 07. Now that it's getting colder and wet again, it's back with a vengeance and very annoying since it seems to have gotten worse. It used to be mostly just over speed bumps but now it does it on a lot of road bumps too.
Going to complain yet again when I bring it in for service and hope it can be fixed before I run out of warranty in a few months.
2007 e92 328i Sparkling Graphite | Sport package | Gray poplar wood | Rogue Ikon exhaust
09-14-2010, 06:21 AM | #6 |
103
Rep 2,783
Why do people expect cars not to require any maintenance? 82,000 miles and you are wondering why your suspension is making noise and needs to be inspected? It doesn't matter if you baby the car; age/mileage also plays a role.
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
09-14-2010, 09:20 PM | #7 |
62
Rep 1,452
How can you tell if your shocks, springs, suspension need to be replaced? Is it by feeling the way the car drives or is it something that can be measured, similar to brake pad and rotor thickness?
I have similar noise when I go over speed bumps.
09-15-2010, 08:52 AM | #8 |
173
Rep 3,415
You can tell if the springs are in need of replacement by a change in the stock suspension setup ride height. BMW measures the ride height by the distance of the bottom lip of the fenderwell directy above the axel to the street. Shocks are really worn out when they start to leak oil, but shocks to degrade over time and you can tell by bouncing the suspension and seeing how many times the car moves up and down before it stops. On BMWs with such tight suspensions this test is not such a good inticator. The best way is to see how the car drives. The suspension loosens up over time due to wear of the many components of the suspension such as ball joints and bushings. If the suspension can't be set to hold the stock alignment, then components are worn to the point of replacement.
10-06-2012, 03:21 PM | #10 |
46
Rep 663
Grave digging!
Sorry to drag this topic out of the grave, and on my first post too.
However I googled this exact issue and have same problem. I wonder if the OP ever had this fixed, and if so how? Thanks! |
10-07-2012, 04:02 AM | #11 | |
167
Rep 2,210
This problem just reared it's ugly head on my FK Silverline X's so I went with HPA's Koni/Swift setup. |
10-07-2012, 01:21 PM | #12 |
34
Rep 150
Hey,
Had this exact same problem this weekend on my 2009 E82 with only 24k miles on it. I only noticed the noise on speed bumps. Front sway bar bushings were replaced and problem is gone. I dont know if the same applies to the E9x as well? |
10-07-2012, 04:29 PM | #13 |
46
Rep 663
I had a good look at my front springs + shocks, and both sides look identical.
While I was there, I did notice the front driver side (right hand drive) was ever so slightly lower. My very unsientific test was to put my fist on the top of the tire. On the passenger side, my fist fits between the tire an the arch. Touching both. On the driver side, I can only get 4 fingers in the gap. This all point to it being the shock? If so, should these be done in pairs? |
