EVO 4g??
12-08-2010, 08:55 PM | #3 |
49
Rep 201
hey, do either of you have any problems with the evo 4g routing calls to the phone handset itself instead of the car? Usually my first call when in the car connects fine through the car, but after that, it goes to the phone. I have to like turn off bt and back on and its hit or miss before I get it working again. Any similar experience?
12-08-2010, 08:59 PM | #4 |
46
Rep 541
Are you answering with the button on the car or on the phone itself? HTC phones (and maybe all androids) have a "feature" whereby if you hit "answer" on the phone, it assumes you don't want to answer with the bluetooth.
12-08-2010, 09:01 PM | #5 |
49
Rep 201
Well, I haven't really tried it for incoming calls. What I noticed happens is I make a call, talk, then disconnect. Then, I try to go make another call, sometimes the phone is disconnected at that point and I can't even see the phonebook. If I hit a shortcut I have saved, it then says no phone is disconnected. So I guess to be more accurate, the phone disconnects after the first call, hence causing calls to get routed to the phone and no chance to even answer on the car. Any ideas?
