For those with H&R Sways... (Poll)
View Poll Results: Did you get both sways, or only the rear? | |||
Front and Rear | 10 | 58.82% | |
Rear Only | 7 | 41.18% | |
Voters: 17. You may not vote on this poll |
12-14-2006, 06:30 PM | #1 |
193
Rep 3,469
Hey Everyone,
Ive been reading up and I see some say just get the Rear sway as its the one making the difference in handling. But I see others who say to get both, that even that 1mm difference in the front is very important as well. Also, did you have any problems such as instability, excessive oversteer, etc. from only replacing the Rear Sway? Thanks,
2016 Alpine White M3 (gone)
2019 Alfa Romeo Guilia (Totaled) 2020 Car-less 😁 (no more) 2020 M340 |
12-14-2006, 06:54 PM | #3 |
boku no namae ha...
336
Rep 11,025
Drives: 2006 BS 330i
Location: S. Bay Area, CA + Newark, NJ + ChiCity + True Blue
i got both too... but the fronts arent as substantially thicker as the rears.
looking for a PreLCI Black Sapphire e90 front bumper without license plate holes
"Akimbo shotguns. Broken wrists anyone? And don't give me that 'it's just a game' bull****. Where the **** are my akimbo interventions then?! One scope on each eye mother****er!!" |
12-14-2006, 07:41 PM | #4 | |
193
Rep 3,469
12-17-2006, 12:09 AM | #5 | |
MAUI BUILT
485
Rep 7,781
Drives: 2006 330i MT
If you do go with the rear only, I'm positive you would find it great!! Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
12-18-2006, 06:24 PM | #7 | |
193
Rep 3,469
12-18-2006, 06:25 PM | #8 | |
193
Rep 3,469
12-18-2006, 06:31 PM | #9 |
23
Rep 669
From what I hear, the rear sways will make the biggest difference.
Don't drive faster than your Angel can fly... BBS CK 19" / Eibach Pro-Kit / Koni FSD / Blacklines / M-tech |
12-18-2006, 07:34 PM | #10 | |
MAUI BUILT
485
Rep 7,781
Danny
12-18-2006, 07:45 PM | #11 | |
148
Rep 5,104
12-18-2006, 08:37 PM | #12 |
24k GOLD
148
Rep 1,453
my friends are installing sways on their G. they told me to get a set too but i figure x-drive doesnt need it ? dont even know if they sell it for x-drive.
12-18-2006, 08:57 PM | #13 |
37
Rep 191
RWD Cars benefit from Front Bars and FWD/AWD Cars benefit from Rear Bars. Depending on thickness of the bars over OEM and the delta between the two bars (Front & Rear) if you change nothing on the car, will determine if the car under/overstears or remains neutral.
I plan on working on my own adjustable bar when I get the car. The S2000 community had plenty of good options for adjustable sways. I have to see how this car is setup and determine if spherical adjustable endlinks will work. Increasing the thickness of the rear bad on a RWD car is just going to make the car overstear and slide very quickly.
2018 McLaren 720S MSO Onyx Black/Scoria Gray
2024 BMW M3cs Sapphie Black/Black 2018 Porsche Macan Sport Volcano Grey/Black 2014 BMW X3 M-Sport Carbon Black/Mojave Brown - Beater |
12-18-2006, 09:28 PM | #14 |
576
Rep 6,750
I would like to see an E90 with just the H&R rear sway bar.
After having just the front one put in, the car plowed horribly when braking hard and turning quickly. Then after the rear one was installed, the car felt balanced again. The only negative comment I have about the stiffer front bar is that it makes going over speed bumps diagonally more bone jarring. |
12-18-2006, 09:36 PM | #15 | |
boku no namae ha...
336
Rep 11,025
12-18-2006, 09:38 PM | #16 | |
576
Rep 6,750
12-18-2006, 09:51 PM | #17 | |
YUGO is my dream car
144
Rep 1,564
12-18-2006, 11:29 PM | #18 | |
boku no namae ha...
336
Rep 11,025
12-19-2006, 11:13 AM | #19 |
50
Rep 1,159
I've had rear only and I've had full sets on other cars. Here's the issues I've had.
With a full adjustable set you get more ability to fine tune. Instead of the 2 or 3 settings in the rear you usually also get 2 settings up front. Stiffer front bar means that you can get quicker/sharper turn-in at the expensive of having to balance out understeer. Which is easy enough to do with the rear bar. If you go rear bar only, you're only adjusting the handling of the rear end. Which means you're tuning how much oversteer you want out of the car only. Which is fine, nothing wrong with that. I actually preferred that ... and this is why. Anybody who says stiffer sways don't impact ride quality hasn't had much experience with them, or their roads are nice and smooth. The statement is true *if* both wheels hit the bump at the same time. If only one wheel is hitting a bump, it's going to be a lot harsher. I've also yet to have an aftermarket adjustable bar that didn't make contact with some part of the suspension under some circumstance. Usually full droop. I even had one that when set to full stiff would hit the drive shaft ... just needed to quick 1/8" ground off the end but still it was annoying to have to pull the bar. And in the case of the e90 that would mean pulling the whole rear subframe. Also keep in mind that the urethane bushings will start to squeek after a year or so requiring you to, again, pull the bar and relube them. Which .... yet again ... in the case of the e90 is extremely prohibitive. Unless somebody comes up with a bushing carrier with a lube nipple on it. |
12-19-2006, 11:37 AM | #20 |
boku no namae ha...
336
Rep 11,025
oh yeah another question mr frogman, do u plan to ever relubricate your brushings? i know h&r states that you dont have to... and that they should never squeak...
12-20-2006, 12:56 PM | #21 |
193
Rep 3,469
Well, I got the rear installed yesterday because thats all they had in stock, and I plan on getting the front one later on, I think I havent driven it much but so far I have no compaints and tons of positives. The car steers sharper and the body remains much flatter. Im a bit concerned that if I ad the front, it will start to plow more in the front than it does now.
12-20-2006, 01:04 PM | #22 | |
576
Rep 6,750
