Hi Shiv, any updates on this?
12-07-2006, 03:26 PM | #1 |
50
Rep 1,600
Drives: e90 335i
From 7:00 AM yesterday
aw shucks... quit it I'm going to be dyno tuning another Steptronic today and will try out some of the new ideas being tossed around. William-- I may give you a call to talk more about what you mentioned the other day regarding holding a gear. -shiv I know we are spoiled but I am very curious about the second Steptronic equipped car you tuned yesterday? Did it actually happen and if some how'd it go. Would love to hear the numbers and details, Thanks |
12-07-2006, 03:42 PM | #2 | |
1736
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
We did the installation and every turned out as expected. However, we didn't dyno test the car since we still haven't found a good way to keep the Step from downshifting. I'm looking into that at the moment. If there is no way, we'll just go back to doing what we did in Texas (4000rpm to 7000rpm pull). Fine for tuning and power verification, but kinda lame since we can't demonstrate what the bottom half of the powerband looks like. But then again, with a Step, users aren't going to find a condition where they are WOT at under 4000rpm. So I guess it's not all bad. The customer, who wants to remain nameless, provided me a review to post up. I'll do that when I get back to the office later today. Like Mr. X and Mr. Y from Canada, he wanted to remain nameless -shiv |
12-07-2006, 04:22 PM | #3 | |
273
Rep 6,510
I am at WOT at under 4000rpm more than I am WOT at above 4000rpm... Not sure what you were trying to say here... |
12-07-2006, 04:25 PM | #4 | |
1736
Rep 17,960
Drives: A Lot
-shiv |
12-07-2006, 04:28 PM | #5 | |
273
Rep 6,510
Long answer... It will downshift while in manual mode only under 3 conditions... 1. Under 20mph it will not go above 3rd. 2. Under 10mph it will not go above 2nd. 3. While pushing the kickdown, it will shift into the lowest possible gear. Remember this post? http://www.e90post.com/forums/showthread.php?t=38707 Also, make sure you have the lever in DS mode, and then do your first manual shift with the lever, then the car will be in manual mode for shifting with paddles or the stick until you move the lever back over to the right. |
12-07-2006, 04:38 PM | #6 | |
1736
Rep 17,960
Drives: A Lot
Shiv |
12-07-2006, 04:48 PM | #7 | |
273
Rep 6,510
I would like to see what happens if you try the following... I came up with this after speaking with a local dyno shop -Pull the 335i onto the dyno. -Completly disable DTC/DSC (hold for 4sec) -move lever to DS -upshift once into 2nd gear with the stick (all while not moving, it will hold in 2nd) -roll up to 25mph -shift the car into 4th with the stick, stay at 25mph -start your dyno run at WOT (DO NOT HIT THE KICKDOWN!, lightly press pedal til it stops) theoretically, the car should not throw the abs fault until after run is over, if you did it fast enough... They also said you should not get a DSC warning if you disabled it first good luck! |
12-08-2006, 01:29 PM | #8 |
50
Rep 1,600
Drives: e90 335i
Was that 91 Oct Steptronic anonymous review up yet? Maybe it went to another thread. Just checking
12-08-2006, 08:10 PM | #9 | ||
1736
Rep 17,960
Drives: A Lot
http://www.e90post.com/forums/showpo...55&postcount=7 Cheers, shiv |
12-10-2006, 12:46 AM | #10 |
50
Rep 1,600
Drives: e90 335i
Nice review. I'm getting antsy for an xede
